Carrera III wheels on my 996
Finally got the tires and spacers and found the time to get everything mounted..
Had the sport design wheels on and loved the look but they where a b*tch to clean so got the 997 Carrera III's which are simple and easy to keep clean. I think it make my car more "modern" looking
Looks good - I think I just saw the side view before you edited the post.
Have any old pics of the car with the old wheels?
I think they are the same rims you have now that I have on my 40th Anniversary Edition, except for the polished aspect.
Here is an older pic... I wish the image code was editable here so I can resize in html code instead of on tinypic.com where the interface was created by drunk monkeys...
more... having resize issues...
Was considering 19s but then smartened up (Drive on horrible NYC roads) so the search was on for 18's. fronts required 7mm spacers to bring them out a bit.
It looks like on the bottom pic the fronts can come out another 6-7mm; so put 13-14mm spacers up front and put the 7mm out back. It will def add a better look, not to mention, you'll feel an improvement in the tracking with the spacers up front.
I can definitely get away with bigger spacers all around. The spacers I currently have put the 8" et 57 wheel at et50 which is the stock offset upfront. The rears are et58 and are slightly more aggressive then the oem et65. Im ok with this set up at this point.
Just came back from a "test" drive and I am amazed at these htrz III's they are softer over road bumps then the 17" bridgestones they replaced and are FAR softer and quieter then the OEM spec continentals I had on previously. I have to admit I didnt know tires can be SO different in the same size.
much improved, thumbs up when you pass me on the freeway
it looks like you are having the same problem i am having cleaning insides those carrera classics, you have a dirty strip as i do after i roll the car into the garage, so frustrating.
+1 on easy to clean !
911mike99?!
