RennTech.org will get your code for you. It cost to join but it is well worth. They have a lot of tech info including manuals for 996 & accessories, TSB etc.
RennTech can get the code for you most of the time, but it's not guaranteed. You can call Becker and get the code too - I think they charge about $35 for it.
I thought they had memory in later years?
BTW you can get a little unit that plugs into the cigarrette lighter that will keep the power for the memor "ON"
OK -- I'm a Renntech member so I will ask Loren for the code -- but -- after doing some more "threading" I am thinking all CDR23s are the "late type" and that the cdr22 is the one that needs to code -- mine has the amp box in the front trunk back a bit behind the top of the spare wheel.
Any clarification?
CDR-23 (or later):
These radios do not have a security code - that is, not that the user enters.
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. Only a dealer or shop with a PST2 or PIWIS tester can replace a MOST bus radio (i.e. CDR-23, CDR-24).
Thanks Loren -- I just went to the radio code thread you maintain and read that so I cut and came back her to post and ya' beat me -- thanks for the help -- the regulars like me that worry a bit when diving into their cars are given confidence by you generous folk who help us -- thanks again
I'd like to install a used CDR23 in my '78SC. Is this going to be possible?
[/B]
Originally Posted by Loren
CDR-23 (or later):
