What is the dry sump for?
It is the holding container for the engine oil rather than having it in the sump below the crank. Many motorcycles and race cars have done this, it makes more sence as it doesn't allow oil to drag the crank and starve in high G corners. The oil pump is 2 pumps in one, a feed and scavenge.
Professor of Pending Projects
And, fyi, the 996 does not have a dry sump setup. When Porsche went from the 993 to the 996 they went with a different oil system... only the 996TT and GT3/GT2 kept the dry sump system and the older engine block.
When the 996 came out Porsche tried to use some bs description to make it sound like a dry sump, which was not... The engine in the 996 is designed with what Porsche calls "integrated dry sump oiling". This "integrated dry sump" engine does not have an oil scavenge pump in the crankcase to pump the engine oil to a separate holding tank outside the crankcase as a true dry sump design would have. The only scavenge pumps in the 996 engine are in the camshaft boxes and the oil is pumped from there to the bottom of the crankcase as it would be in any "wet sump" engine.
![order](https://rennlist.com/forums/graemlins/order.gif)
