Changing exhaust tips....
I was able to change the exhaust tip on the driver's side by getting to the clamp. I can get to the passenger side clamp but the GD clamp bolt spins. I don't have the room to put something on the other end to stop the spin.
Parts Specialist
good luck - iirc once they loosen a little they can be rotated to gain better access BUT rotate one dirrection better than the other so you might have to go "all the way around"
I took the can out. The head of the clamp bolt was not seated right..the concave part of the bolt head was not on the flange portion of the clamp which is why the bolt was turning. It was not locked in place. Cleaned up the threads and all back to together.
Thanks for the words of wisdom guys.
Parts Specialist
awe - cleaning the bolts work fine... I took mine out 3-4 times and re-used the bolts, after the first round they were easy to remove...
where the H&LL are the pics !!
