IMS Bearing Replacement In Progress.....*Complete*
#62
What grease did you use for this?
Thanks for laying the groundwork for me gentlemen. I'm kind of getting stoked for doing this job now.
#64
Are you talking about greasing the black plastic splined collar that the throwout bearing rides on?
Are you referring to the rear engine support - the two motor mounts at the muffler end of the car?
#65
i was able to reach up and use a short 3/8 drive ratchet with a 16mm socket and i could turn it about 1/4 turn at a time.. it was hard because your hand goes numb from using it above your head...
#66
Nice job! And fast too! Mine is still sitting on jacks in the garage after I don't know how many months! Just too busy with everthing else to go play...
#68
Yeah being the DD does put it into priority. I got sucked into an out of town wedding this weekend and the last month I drove 2890 miles of business miles (not including commute and other driving, and the 450 miles to the wedding). Driving is not top priority for me right now!
#71
Hi i was reading through the tread, All looking good.... I too was looking at replacing my RMS IMS seals and would really like to gather as much info as posible on the subject. can i ask where you obtained any information..
thanks again
thanks again
#72
996erme, if I recall there are actually instructions with the LN Bearing but I got most of my info from this thread as well. https://rennlist.com/forums/996-foru...t-bearing.html
Let us know if you have any other questions...
#74
heres mine after it was completed 3 months ago:
#75
as far as the insturctions on the LN engineered bearing, they recomend sealant when installing the IMS...its written in the instruction booklet they send with the bearing...**i didn't see the special sealant on your bearing bolts or center bolt?
