Driver's side vent not functioning
Anyone able to explain why the driver side vent isn't blowing out air? Every other vent in the car is working fine. No matter what vents/AC/heat/etc that I enable, the driver side vent isn't actively blowing air.
With the sunroof cracked or window down, I can feel a draft of air coming out of the vent, but it certainly isn't blowing the air out.
Has anyone ever come across this? Didn't pick up anything on a forum search.
Much missed
Is the vent tube under the cluster gauge missing or blocked? It may be disconnected on one end?
If it is in place, I would pull it to see if air is blowing closer to the blower motor.
Here are some pictures of what the ducting looks like with the dash removed. The passenger side shows both pieces connected. (it is almost identical to the driver's side) It should be an easy fix.
You guys nailed it...
The ductwork was not fully connected on the left side.
Easy fix as you mentioned. Now working perfectly. Thanks for the help.
