996 Forum 1999-2005
woops - 2nd gear redline
Old 03-31-2010, 12:35 PM
Doug996InKC
Doug996InKC's Avatar
Default woops - 2nd gear redline
Was cruising the other day when I decided to get on it in 2nd gear. Normally I can tell by the sound of the engine, combined with the exhaust note, when to shift before redline, but this time, with the stereo turned up louder than normal, not only did I hit redline, but I stayed there for a few seconds. In fact, I felt the car discontinue accelerating! Is there a fuel cut-off protection of some sorts to protect the crank & cams from spinning into oblivion?
Old 03-31-2010, 12:54 PM
redridge
redridge's Avatar
yep, throttle over-rev protection. This is a good over-rev, the other one.... not so good.
Old 03-31-2010, 01:19 PM
Doug996InKC
Thx redridge. How does one achieve the "other one"? Hold redline for more than "n" seconds?
Old 03-31-2010, 01:25 PM
Tippy
Tippy's Avatar
Be in 4th gear at redline, then drop into 2nd like I did......mechanical overrev
Or, worse yet, go from 6th to 1st......yowzer!!!
Old 03-31-2010, 01:37 PM
himself
himself's Avatar
I have hit the rev limiter many times on the street and on the track. Sometimes on the track I bang off the limiter for a couple seconds due to gearing on certain straights. No worries.
-td
Old 03-31-2010, 01:42 PM
Tippy
Tippy's Avatar
-td
Until someoen wants the print out of type 1 overrevs......then ruhroh
Old 03-31-2010, 02:22 PM
Shark Attack
Shark Attack's Avatar
Ouch!
Old 03-31-2010, 03:26 PM
peavynation
peavynation's Avatar
No doubt, ouch!
When I had the PPI done on my car, I asked for a computer scan to see how many Type 1 and Type 2's there were. Lot's of Type 1's, but (thank goodness) not a single Type 2. This combined with my second gear syncro issue (grinding only when cold when downshifting to second, fine upshifting, and fine up and down when hot) makes me think the car was tracked a bit before I got it, and by someone who wasn't too experienced. But so far so good, not a single problem, 54k, original RMS and IMS, runs strong, and God willing, it will continue to. When I swap the trans I will pop in a new clutch and do the IMS upgrade.
BTW, I dig the color, Doug!
Old 03-31-2010, 03:29 PM
himself
himself's Avatar
? People have problems with type 1's? Not me. I bought my car with many thousand type 1's, and sold it with many more. Same with the GT3 when I bought it. It happens. The electronics insure that type 1 does not harm the engine.
-td
Old 03-31-2010, 03:36 PM
peavynation
-td
Same here, and I agree. I started a thread awhile back that showed that there could be some benefit (to the sealed/oil-starved IMS) of high RPMs for the Pcar. It was data collected by Lin Eng if I remember right. But, everything is a theory, there will always be exceptions, so I say don't *****-foot around it like it's made of glass, drive it the way the way it pleases you (without being stupid), and enjoy the Pcar experience! It's what it's about.
Old 03-31-2010, 03:40 PM
ivangene
Parts Specialist
ivangene's Avatar
+1 for high rpm's are "good" for bearings to film lube (so I have heard)
Old 03-31-2010, 04:05 PM
150shot
150shot's Avatar
I'm guilty. Longer than normal tunnel did it in first gear , it got louder and louder and next thing I know , car sorta quit, I knew I hit it and was like OOPS!
So i made a u turn and went through again of course a bit more careful..=)
Old 04-01-2010, 09:40 PM
dallasboats
dallasboats's Avatar
no worries, the car won't let your bad driving hurt it, unless you decide to remove rev limit with software, eeek.
Old 04-04-2010, 05:01 PM
67FJ45
67FJ45's Avatar
For reasons that should be obvious, overrev on downshift is called a "money shift."
Old 04-04-2010, 05:31 PM
Pac996
Pac996's Avatar
Just look at it as you did your best to clean up the upper reaches of your cylinder walls.
Quick Reply: woops - 2nd gear redline
