Misfire and knocking
Hi -
My pcodes are P0300, P0302, P0305 and P0306. But the catch is that there is a knocking sound that does not exist in idle but appears @1500rpm and above. It seems to appear from the right hand side of the engine?
Model 1999 Carrera 2
Any help appreciated.
Newbies Hospitality Director
OK, here goes....
KST, Welcome to Rennlist. It is customary for Newbies to post pics of their car. So here is your official Rennlist "Newbie Initiation." Come on Newbie, post the @#$%^&* pics!
I'm going back to bed!
Damn Ferd, I was asleep in bed when the "No Pic Newbie" alarm when off. This couldn't have waited 'til morning? < yawn >
OK, here goes....
KST, Welcome to Rennlist. It is customary for Newbies to post pics of their car. So here is your official Rennlist "Newbie Initiation." Come on Newbie, post the @#$%^&* pics!![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I'm going back to bed!![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
OK, here goes....
I'd advise no more running engine, even at idle, until you've had the noise diagnosed by a qualified tech. Even if it turns out to not be an IMS any starting or running the engine can do more harm, more damage, and could render a relatively minor problem ( like a failed cam chain tensioner/guide ) a very serious one if the cam chain should skip/jump some teeth on any of its sprockets, or worse break outright.
Trouble is a shop's probably going to want to do a compression test -- vs. pulling the engine and the cam covers and other covers to examine the various cam chain drives and tensioners, guides, etc. -- which can cause a problem if cam chain skips/jumps one or more teeth or just simply breaks. Even at cranking speed pistons and valves making contact can do serious maybe even fatal engine damage.
Best of luck and I hope I'm wrong and its coil packs and something like a water pump making the knocking noise or something more benign than an IMS rattling around.
Sincerely,
Macster.
This could be something minor or it could be something serious. I'd suggest stopping diagnostics and towing it to a shop.
I mean it's probably just a lifter not seeing oil or a bad spark plug but it could be a chain tensioner or something, we can't say. So just be cautious with it.
