996 Forum 1999-2005
I'm Going in ALONE....LNE Retrofit bearing
Old 02-06-2010 | 06:14 PM
  #61
Shark Attack's Avatar
Shark Attack
Ok the tranny is ready to drop, Here we go.
Huh.. I think they have it super glued together,, LOL
Old 02-06-2010 | 06:34 PM
  #62
Shark Attack
Slight issue.... Hmmmm... I have to re-engineer my engine brace... Its in the way of pull the trans fwd, ****
Old 02-06-2010 | 06:51 PM
  #63
leftlane's Avatar
leftlane
I am really nervous reading this thread, and it's not even my car. I'm about to have a panic attack.
Old 02-06-2010 | 06:55 PM
  #64
Barn996's Avatar
Barn996
Originally Posted by slider172
Wow, You've had your 996 how long? And you've already got it torn apart on the Garage floor.
If you ever pass thru Atlanta, call me so I can buy you a beer.
What went wrong? I never saw in the thread what you are attempting to fix.
He's replacing the IMS with the retrofit from Jake.
Old 02-06-2010 | 07:22 PM
  #65
Shark Attack
taaa daaaaaaaaaaa.
whewwwwwww.... not sure I will be back at it tonight or not
Old 02-06-2010 | 07:24 PM
  #66
Dharn55's Avatar
Dharn55
You are the man. How much sown do you have? Maybe it is not so bad to have the car down for a day or two.
Old 02-06-2010 | 07:39 PM
  #67
4Scargo's Avatar
4Scargo
OH THE AWESOMENSS.....THAT IS TRULY A WHOLE BUCKET FULL OF AWSOMENSS!! You're my idol.....
Old 02-06-2010 | 08:03 PM
  #68
Barn996's Avatar
Barn996
Originally Posted by Shark Attack
taaa daaaaaaaaaaa.
You certainly deserve the 'brass *****' award in my book. I thought I was doing well after changing out my exhaust system. Take a break and have a few cocktails tonight.
Old 02-06-2010 | 08:04 PM
  #69
falcon7x7's Avatar
falcon7x7
what the f*&ck? What kind of ******* bolt is that on the bottom of the tranny. Looka like a torx with more splines... WTF? I dont have a tool to loosen that. **** Me
Set up a VIDEO CAM!!!! This would be great!
Old 02-06-2010 | 08:07 PM
  #70
falcon7x7's Avatar
falcon7x7
taaa daaaaaaaaaaa.
You be the man!
  #71
juankimalo's Avatar
juankimalo
Having Jake's support in this forum is fantastic.
I'm purchasing this Kit and other things to reinforce my engine too. But I'm going to tell you how someone did a home made retrofit kit in his 996...
In Soloporsche.com we have a hero. Someone who did something similar to LN Engineering, last year.
http://soloporsche.com/showthread.php?t=33716
"Barracuda", a soloporscher user, opened his engine to check the IMS. He built a hand made extraction tool to check the single row bearing (996 '03). He's car had 115.000 km, and the bearing was in perfect condiction. Nevertheless he decided to change the bearing for a new one to keep the reability of the engine for 100.000 km more.
He searched the bearing in one of the world wide best know bearing manufacturer: SKF. Someone advise him to go for a ceramic compound reference instead of the OEM steel bearing. So he purchased this one:
SKF Part number = 6204-2RSLTN9/HC5C3WT (Price 110 $)
After that he thought that the bearing support wasn't strong enough and ordered to make a reinforced hand made to a professional lathe operator. He made a 12 mm high quality steel bolt instead of the 8 mm OEM bolt, and asked him to adapt the 3 flange end piece to the new bolt caliber.
Besides, he told us that he prefers to leave the bearing out both circlips to allow the engine oil running through the bearing *****. He argumented that the oil was inside the bearing, mixing to the ***** grease, and was easy to come in but not too easy to get out the bearing, with the result of having contaminated oil into the bearing. This could make the ***** to fail in the future, so he decided to allow clean engine running through the *****. To seal the hollow shaft tube, he used a hand made cork seal. Besides, he change the engine oil every 5.000 miles (Mobil 1 5W50) to keep the engine free from wear.
I know all of this, is a bit rare, but his car is running fantastic.
Old 02-06-2010 | 08:28 PM
  #72
ivangene's Avatar
ivangene
Parts Specialist
actually those pics are great... I understand now how the bearing is held in AND how it comes out....his tool is simple but the mechanics of it are easy to understand, so that might help....
good post.
Hey Kyle....
just an FYI, that tranny doesnt "click" into place when going back in....the bell housing will be slightly apart (unlike the old american cars where they are seated prior to puttin gin the bolts)
You are pretty close.....!
Old 02-06-2010 | 09:03 PM
  #73
Shark Attack
I am going to have a few hours on it tonight yet. I am hoping to ATLEAST have the bearing exposed....
I am sore. My body is reminding me I am not 25 years old anymore
Old 02-06-2010 | 09:49 PM
  #74
Shark Attack
rut roe, blood on the garage floor..... damn clutch caught my finger between the cross member and the clutch. Dont ask
Old 02-06-2010 | 10:04 PM
  #75
Shark Attack
flywheel bolts are out. Need to consult WSM and see how it comes off:
EDIT: It just slides off. It sits on a small pin. I gently pryed it off.. It took very little effort
Quick Reply: I'm Going in ALONE....LNE Retrofit bearing
