996 Forum 1999-2005
40th Aniversary 911
Old 12-21-2009, 01:07 PM
riderosa
riderosa's Avatar
Default 40th Aniversary 911
I am very blessed to have a 40th Anniversary 911 with only 30K miles. The power is good but I am curious to learn if there are any tuning mods that could be made to improve the HP and Torque? Certainly a SC or Turbo is out of the question.
Old 12-21-2009, 01:20 PM
russo
russo's Avatar
Unless you supercharge it or put the car on a diet you will be hard pressed to notice any significant changes by doing the usual mods of intake/exhaust/chip.
Old 12-21-2009, 02:09 PM
Mabuhay
Mabuhay's Avatar
Originally Posted by riderosa
... tuning mods that could be made to improve the HP and Torque? Certainly a SC or Turbo is out of the question.
Anything else aside from a SC or Turbo will only yield you "mental" results...
Old 12-21-2009, 02:15 PM
ivangene
Parts Specialist
ivangene's Avatar
K&N CAI adds 30HP
Why do you feel you want more power BTW? What is it you are missing, and how do you think more power will help the issue.
Old 12-21-2009, 02:23 PM
ROK
ROK's Avatar
I just got 20hp from 5-7K RPM over stock with my custom header/exhaust/cat setup. Below 5K about the same. Shaved 65lbs off the rear, too.
It's possible.
SH || NC
SH || NC's Avatar
Take it to the track
Old 12-21-2009, 02:43 PM
himself
himself's Avatar
The Anniversary model is probably the third best naturally aspirated 996 model in terms of HP and torque. You won't be able to get much more out of it. And trying to get 10-20 more HP is very expensive, with mixed results.
As Whitey said, take it to the track and you'll see.
IMO, the mod money is probably best spent elsewhere.
-td
Old 12-21-2009, 02:53 PM
ivangene
Parts Specialist
ivangene's Avatar
+1 for spend some time at the track and if the claims of 20hp can be made from simple exhaust swap, dont you think Porsche would have done it already?
Less weight I believe, better sound... ok...
Even if I had another 20 HP I doubt I would be able to really feel the differance other than in my head. Track lap times on 20+ more HP would would be very tough to see any change IMO - now money spent keeping the tires on the ground and your butt in the seat.... that will show up !
back to my original Q : why do you think you need more HP/Torque
Jake Raby
Jake Raby's Avatar
I agree. The package is well optimized from the factory.
I tuned one to 340RWHP but I had to pop it open and make it bigger to do it along with more head work, etc, etc. :-)
Its hard to beat right out of the box. Most of what you will do will result in LESS net output.
Old 12-22-2009, 04:55 PM
riderosa
riderosa's Avatar
Thanks to all. This question was for for my curiosity than anything else. The power and handling is certainly more than I can master now.
Old 12-23-2009, 11:30 PM
cdaniels
cdaniels's Avatar
What does the 40th Anniversary 911 weigh stock?
Old 12-24-2009, 12:45 AM
Optical TDI
Optical TDI's Avatar
I drove a 40th back to back to a 2005 997. The 40th's motor was much better in my opinion. I liked how it revved and how the motor sounded. Much quicker revving as it felt like the flywheel may be lighter. Or it could be the motor internals as well. It just sold at the dealer I bought my 2002 996 for $46,000. That 40th had around 15-20k miles and nearly flawless.
Old 12-24-2009, 12:49 AM
garrett376
garrett376's Avatar
3400 wet would be pretty close. Lots of options, lots of weight!
Old 12-24-2009, 12:53 AM
red911c2
red911c2's Avatar
-td
OK, I know the GT3 is higher but what other naturally aspirated 996 model is higher in HP/Torque? I'm drawing a blank...
Old 12-24-2009, 11:38 AM
rodsky
rodsky's Avatar
My question too?? I think apart from the GT3, the 40th was the fastest NA 996.
Quick Reply: 40th Aniversary 911
