Trans Oil
Trans Oil
I am changing out all the fluids as there is no service history on my 2001 that was recently purchased (yes, Pics on the way!)...
What is the best oil / fluid to use in the 6 speed? I have just under 40,000 miles....
Do a search on past threads and you'll find all sorts of recommendations and opinions.
I say go with Porsche recommended unless you're having syncro issues (like me) in which case I'd use Redline 75-90NS. NS stands for no-slip; slip agents aren't added to this version, thus helping worn syncros match up speeds easier.
Just don't use it if you have an LSD in your trans, unless you're only tracking the car (some do it on the street, but it's a bit chirpy for my taste).
LN Engineering has the Mobil 1 Delvac that is the OEM rec in smaller containers. The Delvac is different the the Mobil 1 gearlube you will find in the auto stores.
