Need winter wheel/tire help!
Team Owner
Tire Rack has great occasional deals on 'scratch & dent' wheels - I got a set of 17" turbo twists and put on Dunlop snow tires on my '02 C4. It's a great setup for snowy Colorado winters - I am very pleased and it was a very affordable setup. Don't try to cut too many corners here - one slip off the road and you'll be cursing yourself for being a cheapskate.
Are the Tire Rack scratch and dent deals available online or do I have to call? I wonder if Damon could help me with that...
I wonder if your specs are correct on option #3?
Original equipment on a 996NB C4(at least mine) is as follows:
Front: 17" x 7" rim with 50 offset and 5x130 bolt pattern and 205/50/17 tires
Rear: 17" x 9" rim with 55 offset and 5x130 bolt pattern and 255/40/17 tires.
I currently use this setup for my winter wheels and it does quite well. The idea that the marginal loss of contact area from 18" to 17" wheels somehow makes the car dangerous is imagined, at best.
+1 on the 17" winter wheels and tires being cheaper and easier to get.
Helo Driver
Just put on Bridgestone LM60's on my C4S.(275 rear) What pressures are you running on the snowtires?
gaspasser and fbgh2o are both right about the narrower wheels. The 65 offset is for a 10"wide wheel. If you use a 9" wide wheel then the 10mm difference between a 55 and a 65 offset is "offset" by the narrower width.
Here is an offset calculator that will allow you to see the differences in inner and outer clearance.
http://www.1010tires.com/WheelOffsetCalculator.asp
Team Owner
Thanks for everyone's help so far...
