Cruise control -- not like 964???
Previously I had a 1990 964 -- great car -- still think about it.
Now I have a 2002 3.6 996 Targa 6 speed manual.
When using the cruise control I have to reset it if I change gear -- using the clutch "unsets" it.
In the 964 you could set the cruise control in 4th gear and then change up to 5th gear and as soon as you got off the clutch the cruise control was back on.
Can the 996 cruise control be set up to operate like the 964?
Also the 964 cruise control was more acurate in fine tuning the speed -- you seemed to be able to go up 1klm at a time -- the 996 is 2 klm at a time -- and it says so inthe manual (I recall) -- can the fineness/sensativity of the cruise control be set?
Ask Toyota about that (you may have heard they're recalling cars and changing electronic processes to address unintented acceleration issues).
Poseur
I've never used my cruise control. It's too much fun controlling the car with the throttle, and mixing up the gears. Sitting in 6th with the cruise on would be boring to me.
That said, I would think stepping on the brake or the clutch would de-activate the cruise control. If you're down-shifting, you would need to match revs, not relying on the cruise. Up shifting, you would want to give it more gas. Not the time to have the cruise on, IMHO.
