996 Forum 1999-2005
Changed MAF, No Change!!
Old Oct 28, 2009 | 11:33 AM
pszikla's Avatar
pszikla
Default Changed MAF, No Change!!
To refresh my problem last week............
Drove car all day last Thurs. without any problem but late in the day when coming up to a stop sign engine stopped.
Started right up but wouldn't idle. Had to keep rpm's at 1500 to keep from stalling.
Nursed it to my indy, put Durametric on it and only fault registered was MAF sensor.
Ordered one , installed it yesterday and still same problem, won't stay running at idle.
Cleared fault code, drove it for 5 minutes, back on Durametric and gives same fault.
Any ideas?
thanks
Pete
Old Oct 28, 2009 | 11:40 AM
pete95zhn's Avatar
pete95zhn
Former Vendor
Did you disconnect the battery? IIRC I read from somewhere that it's requred for teaching Motronic it has a new partner.
Old Oct 28, 2009 | 12:16 PM
SH || NC's Avatar
SH || NC
Vacuum leak?
Old Oct 28, 2009 | 12:26 PM
Macster's Avatar
Macster
Any ideas?
thanks
Pete
What was/are/is the error code(s)?
If codes cleared no need to disconnect battery. Clearing codes resets long term fuel trims back to defaults.
Post the codes. And you probably should avoid driving the car. Might be AOS and this can present risk of serious engine damage if you keep driving the car.
You can sometimes eliminate the MAF from the list of suspects by disconnecting the MAF from the wiring harness and then driving the car. Check engine light may come on cause the MAF's disconnected but the engine should run ok, if the MAF was causing the problem.
Any recent service/work done to the engine, or car?
Sincerely,
Macster.
Old Oct 28, 2009 | 12:49 PM
pszikla's Avatar
pszikla
Hey Macster!
No work done this year at all and she was really running great. The problem was instantanteous.
I'm wondering if it could maybe be the connector, or the wiring that leads back from MAf to computer.
If you get the rpm over 1500 so it won't stall, you can drive the car even at highway speeds as i did when the problem happened, I drove it about 30 miles back to the Indy from where i was.
I drove it gingerly, but i noticed that if i gave it a bit of gas while cruising at highway speed, it would "buck" for a second and then pick up.
Can it be the computer (hope not!!)
Old Oct 28, 2009 | 01:39 PM
Tippy's Avatar
Tippy
Your car will run without the MAF at idle. Durametric failed or the Mechanic read it wrong I'd assume.
Old Oct 28, 2009 | 02:33 PM
pszikla's Avatar
pszikla
Cory, I'd tend to agree on that. However i changed the MAF because I was there while we read the code fault last Thursday and it clearly said MAF sensor as fault.
So now the question is, I've put in a brand new MAF sensor....start the engine, hold the idle with the throttle pedal for a few minutes and then shut it off, attach the Durametric and get the same fault code pointing to the MAF sensor!! Weird!!
Pete
Old Oct 28, 2009 | 02:58 PM
1999Porsche911's Avatar
1999Porsche911
Record all the sensor readings from the durametric and post here.
Old Oct 28, 2009 | 03:03 PM
996kid's Avatar
996kid
6th Gear
hey mate,
My uncle friend had the same problem. The check told him it was the MAF. He changed it and still same problem. The check said again it was the MAF, he bought another one and it worked.
sometimes they can be damaged. Replace it, it should work. Try and get it from somewhere else, it could be a damaged batch..
But this scenario happened for real. Good luck mate.
Old Oct 28, 2009 | 06:28 PM
pszikla's Avatar
pszikla
here are the codes
P0102
P1123
P0154
P1602
pETE
Old Oct 28, 2009 | 11:22 PM
67FJ45's Avatar
67FJ45
here are the codes
P0102
P1123
P0154
P1602
pETE
P0102 is a generic code for mass air flow circuit, low input.
P0154 is a generic code for O2 sensor circuit - no activity detected (bank 2, sensor 1).
P1123 is a Porsche code for O2 sensor circuit fault, bank 1.
These all point to the MAF, but even with a faulty MAF, I would think the O2 sensors would be sending signals to the engine computer. And while I don't have a code list in front of me, I am pretty sure P1602 is a Porsche code for computer or auxiliary output malfunction.
If I were you, I'd first take Cory's advice and see if it idles with the MAF sensor disconnected. And it wouldn't hurt to try another MAF sensor before you go deep on a computer (yuk).
Good luck.
Old Oct 28, 2009 | 11:39 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
NEVER assume that a replacement part isn't itself faulty. Sometimes quality control takes a day off. Try another.
Old Oct 29, 2009 | 10:28 AM
pszikla's Avatar
pszikla
OK gonna try and find a known good sensor through a friend and report back!
Pete
Old Oct 29, 2009 | 10:33 AM
1999Porsche911
If your engine does not idle without the MAF connected, don't plug in another MAF as you may have a short and you will blow the new MAF. What are your sesnor reading as close to idle as possible. O2's, MAF, load, and fuel trim?
M3 Defector's Avatar
M3 Defector
I have 1128 and 1130 error codes and my indy says he's pretty sure it is the MAF. He has a machine that basically fills the entire engine system with smoke to locate vacuum leaks, but he said the 2 hours he spends doing that will likely turn out to be a MAF so he thinks I should just replace it. He's only going to charge me parts.
I did the gas cap recall and the CEL stayed off...until today. I was hoping that was it.
