ignition key won't release
The electric side of the ignition switch is a very common failure. Do a google or rennlist search and u will find threads on replacing it.
Hey buddy, I saw your question about the mechanics of the ignition. My car is having the same issue.
after driving I go to park up and when removing the key it’s like the mechanical part of the lock doesn’t close up so the car acts like the key is still in the ignition. The radio has to be manually turned off. And then the car won’t lock with the alarm so it’s a manual lock which leaves the passenger door unlocked!
did you manage to resolve the issue you had as it sounds very similar to what I’m experiencing just now???
thanks buddy, hope you are well and fingers crossed you reply!
I had a similar experience. I replaced the electrical part of the switch several times, and it would fix the problem temporarily. Eventually replaced the entire steering wheel lock assembly, and now it's MUCH better.
I have a similar problem as described (some years ago...) by the OP: In my case, is not a problem with the key positions or switching on or off the car. Is just releasing the key from the switch. It slides in without problem but when I try to get it out (after switch off the engine) it seems to get trapped. If when I turn the engine off, I push it a bit strong to the left, harder than usual, it would come out easily.
Has anyone have the same problem and solved it by changing the electrical switch?
Thanks!
Thanks!
Thanks!
Thanks!
parris (10-18-2022)
