How To Jack up a P-car
#61
As you can readily see in these pics, I just leave the hardtop on whenever it happens to be on the car and I have to jack it up. Makes no difference.
https://rennlist.com/forums/997-foru...-securely.html
#62
Just thought I would add my experience. I have a stock 2000 996 C2 (no aero skirts, lowered suspension, etc.). I followed the advice above:
1) Lift from rear jack point.
2) Drop car with front resting on jack stand at the front jack point; one 2x4 under rear tire. Remove jack.
3) Repeat on other side of car. Remove jack.
4) The car is now resting on two jack stands at the front, and one 2x4 under each rear tire. There is enough room now to get my relatively bulky jack far enough under the engine to reach the cross member. Lift the rear of the car at the cross member, and then lower the rear on to jack stands at the rear lift points.
Car is very solid on the four jack stands. I'm leaving the jack under the cross member (not lifting) for security.
#63
I have found a perfect solution to the problem of lifting my Porsche in a safe way! I bought one of these that is on the picture below. You mount it on top off your normal garage jack so you get two lifting points (!) on your jack. I don't know what it is called in english (I bought it in Sweden), sorry!
It adds a little hight to the jack so I have to first jack up my car on each side normally (using the rear jacking points) and put some pieces of wood under the tires (about 5"). Then I simply use the jack with the additional device in my picture below to lift the car:
In the front right where the suspension is bolted to the body on each side, and then put jack stands under the Porsche front jacking points.
Rear on each side of the crossmember under the engine (the one pictured above in this thread), and then put jack stands under the Porsche rear jacking points.
This way you can jack up your car to ANY hight without having the car swinging around while you are jacking it up! It is fast and it is safe!! It is also a very cheap solution (I paid about 200 USD for jack and this device)!
HIGHLY RECOMMENDED!
PS. I also use the devicee to lift my other cars when needed!
Robert
HIGHLY RECOMMENDED!
Robert
#64
I started to lift the rear using the engine and both engine mounts leaked! It scared the crap out of me. When I replaced the engine mounts it was clear that they were way beyond their useful life anyway. From now on, I use the engine mount as the lifting point, not the engine.
#65
Ken makes these for the 996's I may buy a set. Makes jacking so much easier.
He goes by Porken on the 928 forum and he sells lots of innovative products.
http://liftbars.com/
#66
Robert
