Contant light throttle, revs rise in neutral: why?
Weathergirl
I tried to do the experiment referenced in the planetporsche thread referenced here: https://rennlist.com/forums/996-foru...-shifting.html where I hold the throttle at ~1000 rpm and push in the clutch pedal to see if it dips.
Only problem is, the revs rise by themselves. I tried this a bunch of times to make sure I wasn't subconsciously pushing harder on the gas pedal. In fact, I even tried to ease pressure slightly to keep the revs down, but there is no doubt: with constant light pressure on the gas pedal the rpms rise slowly at first through 1500, 2000, 2500, got to 3000 even--all with very, very light constant pressure. It is absolutely impossible to maintain a constant off-idle rpm in neutral.
Any idea what's going on? Is it supposed to do that?
Parts Specialist
when I first got the car my Dad told me his "friend" had a Porsche and it started up, drove down the street and hit a light pole in the middle of the night..... all by itself ! ! ! ! !
I think your car wants to drive more... just dont park it without a chain around the wheels!!
Ed, you're so crazy, you crack me up!!
It could have something to do with the clutch pedal switch that the ECU uses for part of a (misunderstood? At least not explained well yet) feature that the P-car uses to modulate the throttle and 'delay' response during clutch pedal transitions. Here's a recent link: https://rennlist.com/forums/996-foru...-shifting.html
My guess is that it's perfectly normal, but I'll try it soon with my 6sp car and see what happens.
Sincerely,
Macster.
It took some effort -- very little pedal pressure and I mean very litte pedal pressure -- but I was able to get a steady RPM out of engine.
And I mean very little pedal pressure. Just a tiny tiny bit of pedal will have the RPMs climbing. I had to "back off" some until it felt like I was barely depressing the pedal at all and RPMs steadied just under 2K. Not sure I would have the patience/desire to try to hit a specific RPM but I was just happy RPMs steadied at all.
I'll bet if I try really hard I'll be able to get a steady RPM from Boxster engine too.
Sincerely,
Macster.
