I hate my car stereo, and I did something about it!
#46
There is no doubt that you can tailor the frequency response car specific with a 12 band equalizer a heck of a lot more than with just bass & treble, but saying that the CD or CDR-220 sounds like garbage is way off. The "all mid lows and mid highs" IS the speakers, not the HU. When you EQ with a new HU you are correcting the speakers weaknesses, obviously not the old HU's, as you just removed it. If you just replace the speakers you will see a 7/10s improvement, and if you could EQ the car with the OE HU in place, a 9/10s improvement. That last tenth is what costs you. Like I said, versatility, options, power, etc are all worth what you are willing to pay to get. The OE HU is almost as basic old school car stereo as you can get, and like everyone else, I'd rather have a blank canvas of standard mounting dimensions for amps, speakers and HUs, but since Porsche didn't give us that (what IS it with all the German car builders and stereos, can't they JUST leave it standard!), I do what I can for the most bang for the buck. With the exception of the double din AVIC type HUs, every other aftermarket HU is just way too disco for my tastes.
#47
The CDR-220 sounds like garbage, it is all mid-lows and mid-highs. If it were a EQ, the settings would resemble a bell curve.
I cant imagine just replacing the speakers and calling it a day.
The Kenwood I was mentioning Andy has "system Q", a sound processing/EQ functionality that allows 12 bands of equalizing.
What I mean is, is you can tune out the harsh frequencies from the little-bitty drivers and boost the lows to compensate for the poor response they put out.
If you just change speakers, you still have a **** sounding signal being sent to great speakers IMO.
Of course, it is the sum of all the parts and speakers, HU, and amp would round out the package.
But, you said $300.
But, you said $300.
Bob - The head unit you have uses LOW 2.5V preamp outs (mentioned in a review as being low compared to more hi-fi units). The Kenwood or JVC HU I would get have higher output preamp voltage - not sure it makes that much of a difference though.
#48
Super Moderator
I agree. So when you changed your HU to the Kenwood, were you able to EQ out the harsh sound and get something more listenable, using the factory amp and speakers??
#49
I added a sub so the lows were covered. But, for mids/highs, it wasnt bad.
Like I said, it isnt audiophile quality but for your budget, I think it sounded fairly good.
The CDR-220 sounds like you said, an AM radio. My Kenwood sounded so brilliant with decent mid range reproduction.
I have an Alpine now and it was barely noticeably better sounding than my factory HU in my 4Runner.
But hey, its just my opinion.
#51
I was all set to order a new HU from Crutchfield, when their website said there was no harness that would work with the factory amp equipped cars. I thought the Audi/VW harness would work - but it looks to have 4 RCA plugs. Is that right, or is there another adapter?
http://www.crutchfield.com/p_1207017...tab=review#tab
#52
You use the front channel on the HU to plug into the front speakers and the door subs on the amp.
The rear channel of the HU plugs into the rear speakers and the subwoofer (if you were to use one) on the amp.
Then, all you need is the power harness adapter.
#53
If I cant get an adapter, stick it on, and plug in to the existing speakers and amp, I'm not doing anything! I won't be getting a sub, and need simplicity!
#54
The non Bose "hifi" uses the low levels from the Becker, not speaker level. The speaker outputs on the HU are not even hooked up. I don't know if thay are high level pre outs or low level, tho. Tippy is right that you will get better tailored frequency out of a 12 band EQ HU than changing the speakers, BUT you are still limited to what the poor OE speakers with paper cones can do. I personally feel (and lets face it, audio is ALL subjective) that just upgrading the speakers gives you more clarity and punch. I may not be able to balance it exactly, but what I have is very listenable. I'll have to look up and see what that Kenwood looks like.
#55
It is plug and play. 15-30 minute install no problem.
#56
Speakers require melting plastic tabs on the grills and resecuring back with potentially different size speakers frames, etc,.
#57
I'd much rather try making the stock system (speakers and amp) sound more pleasing by getting a HU with better equalizer, and get the benefits of iPod connection and HD radio. That is, if the adapter harness will work. I have to pull the Becker unit out and have a look at the connections. I assume the speaker wires all lead to the amp, and the preamp outs (via RCA) come from the HU to the amp inputs, right? Why did Crutchfield say the adapter wont work for this application?
#59
Thats why I would ask an installer who does them regularly, I would have to look at it to figure it out.
The installer gave me all the RCA's and harnesses I needed right there and bought them.
