996 Forum 1999-2005
Just replaced my front hood latch assembly...
Old 08-22-2009 | 03:29 PM
Marlon's Avatar
Marlon
Default Just replaced my front hood latch assembly...
...ahhhh-front hood pops up just like it should now, perfect. Ordered part from Sunset. Easy job too.
Old 08-22-2009 | 04:44 PM
ivangene's Avatar
ivangene
Parts Specialist
wtg Marlon
Old 08-22-2009 | 04:51 PM
Marlon's Avatar
Marlon
Default but wait - there's more...
to top it off I replaced my drivers-side vanity mirror lid too - parts from Sunset. Talked my wife into holding it up while I soldered it. Already had done 'her' side. Now I need to replace the drivers side headlight washer assembly - assuming that all I gotta' do is pull the headlight.
Originally Posted by ivangene
wtg Marlon
Old 08-22-2009 | 04:57 PM
ivangene's Avatar
ivangene
Parts Specialist
when the headlight comes loose from turning the release - it makes a sound that might scare the pants off you like "Sh#@ I just broke the frickin headligh?"
its normal... then a little gentle wiggle while turning the release and it will slide right out - when installing... wiggle very gently so it "falls in" while feeling the release lever with the tool... THEN tighten the release - again - BIG ole SNAP... a bit scary, but normal
Old 08-22-2009 | 07:43 PM
Marlon's Avatar
Marlon
coo-ell - thx! It's raining now, so maybe I'll do it tomorrow!
Old 08-22-2009 | 07:59 PM
ivangene's Avatar
ivangene
Parts Specialist
a rainy day is a great time for an amberectomy
ya know....
Old 08-22-2009 | 08:32 PM
Marlon's Avatar
Marlon
Is that the same thing as a 'pumpkin delete'? If so, I already put the clears in. The Litronics are all clear anyway
ya know....
Old 08-22-2009 | 09:31 PM
ivangene's Avatar
ivangene
Parts Specialist
nope - look at your blinkers in the headlights - amber city -
LINK
read and look at pics - you will see
Old 08-22-2009 | 09:59 PM
Marlon's Avatar
Marlon
W_A_T!?!?! Does anybody actually SEE those teeny little bulbs in the sides??? My front lenses are totally clear...
LINK
Old 08-22-2009 | 10:07 PM
Jon996's Avatar
Jon996
Hi! Just to make sure I order the right part, do you have the part number for the hood latch assembly that you ordered? Would be great to have this working right!
Thanks!
Old 08-22-2009 | 10:13 PM
Marlon's Avatar
Marlon
Cewitanlee - 996-511-053-02 from Sunset: list $144.81, YOUR price: 111.57. Be sure to order some more stuff since it best to consolidate shipping. Need pollen filter??? Clear side set? etc.
Thanks!
Old 08-22-2009 | 11:15 PM
Jon996's Avatar
Jon996
Thanks!
Old 08-23-2009 | 01:01 AM
chsu74's Avatar
chsu74
You can adjust the position of latch by unscrewing the two bolts holding to the front part of the bumper and move it up or down. I bought a new one and while replacing it found the latch mechanism to be adjustable. Try that first.
Old 08-23-2009 | 03:15 AM
ivangene's Avatar
ivangene
Parts Specialist
I notice - every car - every time... and anyone who has done the operation notices too
Old 08-23-2009 | 06:57 AM
Marlon's Avatar
Marlon
Default The adjustment applies mainly to how high or low the front hood edge sits...
...but by all means, try to adjust it first. But if it does not pop up and your hood edge is ok, you likely need a new latch. When you replace yours, you will need to transfer a little clip from the old from your old electrical connection to the new one (it holds the connection tight to the sheet metal in the boot area behind the felt lining). You will see what I mean after you take the electrical part 'apart'.
