First track day in a 996 a bit rough, looking for tips
Parts Specialist
thanks for replys
just for my own knowledge, what class did you put yourself in (beginner / intermediate ? )
the tire presure seems a bit high - anyone else care to comment on that one ? This is on PS2's and hot day out (track temps over 100 my guess)
the camber in front is basically zero...with the US standard I ran those numbers and had some great straight runs (although I was trying to turn - bit of push!!) and I could get the back upset and have it come around quite easy if I wasnt very smooth (which I wasnt a couple times) because of the imput + body roll + lack of slowing down in the head = spin rule (autocross is a bit more forgiving in this event than PR would be)
my last run, last month was by far my best ever. I have to say, I really slowed down...I know it seems backwards, but I was overdriving and over compensating and trying way to hard...I really wanted to be fast.... but when I slowed down, I actually was fast....this is no substitue for more seat time and I hope your next run out will give you a better return on your money/time investment - for me, I hope I remember that last run this weekend and build on that not spread my legs and WEEE all over what little i have learned
Don't beat yourself up over a rough day at the track where you didn't meet your own expectations. My advice is to try it again w/ a good instructor and get back to the very basics:
1. follow an experienced driver to get a feel for the correct line
2. always do your braking in a straight line as you approach the turn
3. slow down enough so you can late-apex each turn
4. gradually increase throttle as you unwind coming out of the turn
Don't try to be fast - try to be good, then perfect before you try at higher speeds. Spend your time feeling the car until you have a high comfort level and remember, you're having FUN!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I don't think I was pushing it too much, actually. Nothing stupid; never got into any trouble. I just wasn't happy with the result.
The Penguin King
Getting some more negative camber in the front will help with the push. But as many have commented here, seat time will also. You've come from a car that has a dramatically different weight distribution. I've watched a number of drivers who are much more experienced and talented than I am jump in my car from their front and mid-engined cars, and have to adjust. They adjust quickly because of their level of talent, but the first lap or two gives them a challenge. Give yourself time.
I go to track days with my brother, who just happens to have a 01 330 with the sports suspension. We trade cars of course.
I know what you mean on the understeer and the overdriving. In comparison, the BMW is far easier to drive to its limits. As you will soon learn, that is part of the 911 addiction. Learning the right speed and right technique to get the car to turn in and then, when you are able to get to the apex with the right speed and car attitude, the ability to get on the throttle with a heroic application of throttle to the end of turn, well, it's truly great stuff.
Alignment, front: Camber @ -.01 & .04.
Alignment, rear: Camber @ -1.09 & -1.01
On my car my alignment specs were:
Camber Front (R/L) -1.99 / -1.99
Caster Front (R/L) 8.0 / 8.0
Toe Front (R/L) .05 / .05
Camber Rear (R/L) -2.48 / -2.52
Toe Rear (R/L) .17 / .17
Parts Specialist
My first run in my car I had the tires pumped up too... I figured that was pretty high and would get some feedback....
so the tread rating on the PS2's is 220, and the Sumi ZIII's is 300... I need a little more air in the sumis than a PS2 (RIGHT?) higher number = harder tire = softer sidewall from what I have been told - will will check them and try for about 40/42 hot
do you take a pump to the track or just fill up at the gas station on the way home or at home once you arrive? -
FWIW, I ran my Sumis on the track a few times in the wet and then when it got dry. I ran them at just under 40. They were fine at those pressures. But in the rain, they were actually quite crappy
Also, at our track, we have trackside support with compressors. I'm sure someone at your DEs will have a tank.
-td
I guess I'll throw my 2 cents worth in although I agree completely that getting a good instructor to help at the track is much more valuable.
To those I contradict, sorry. I could be wrong.
1) Do not brake in a straight line. I teach students on their first day on the track to brake (at least lightly) through turn in. It is very important to keep a little weight on the front. This will really help rotate the car before the apex.
2) Each corner is different but think in terms of a geometric apex. Not early, not late. It's a nice point to adjust from. A late apex seems like the right thing to do if the car is pushing but it's not. If you can, you want the car rotated without taking a late apex line.
3) Try carrying a little more speed and maybe a higher gear. A slow in, fast out approach will make the push worse. At least give it a try. It should allow you to be a little lighter on the throttle in the second half of the corner which will reduce your understeer.
So, brake longer, lighter and though turn in. (Hard and late can come later) Focus on getting the car rotated as much as possible before the apex. Apex where it's right for the corner. Late is seldom the right answer. Carry a little more mid-corner speed. Exit with as much throttle as you can while managing the push. Push is not all bad. At least it's easy to compensate for.
Finally, forget the 330. I have a 650 I took out on the track for fun earlier this year. There is nothing like a few laps in a (non M) BMW to make you love a Porsche.
Jim
Jim
Interesting comments on tire pressures. So you set them up so differently on the track (same pressure F/R, lower pressure) vs normal driving (significantly higher rear pressure)?
Jim
Jim
I don't want to try to diagnose your issue over the internet, but the answer to understeer is to have more weight on the front tires... I remember taking a student (and friend, is the only way I drive student cars) out in his 911 where he was complaining about understeer at the end of turn 1 at VIR, all it took was coming in hotter, I was actually getting some oversteer...
I've known a few people who've switched from M3s -I'm actually one of them- to 911s, the 911 is more fun. Don't judge it from one track event, your first back to the track at that. It is more capable, but more importantly FAR more satisfying to drive. I will voice my opinion on the suspension one more time though, I think the stock suspension is far too soft. You're also not running a lot of camber, about 1.8 degrees front and rear makes the car more balanced but you don't NEED to mess with anything other than getting more experience, in my honest opinion.
Remember, driving fast is all about managing weight. In a car without much platform (race speak for soft) you need to move your weight around carefully. If you are not careful, it's easy to allow your weight to work against you in a soft car. Think about moving it to where you want it slowly. Slow being relative of course.
Does that make sense? Discussing driving on the internet is very difficult.
Jim
Jim
