996 oversteer corrections at Thunderbolt.
Dell I am aware of this too , but do you or do you not agree that say understeering on exit will scrub off more speed/time on r-comps than street tires. This is just something I have noticed and feel like it is supported by what we are both getting at.
As far as the understeer issue, it depends on the situation. But oversteer should be faster if controlled. For example, trailbraking.
This is the sort of thing I'd like to avoid wasting time on, by having you ride in my car or let me ride in yours. You go to VIR often enough don't you?
Or on corner exit...
Actually, slip angle changes depending on many factors, "optimal" slip angle is smaller on street tires.
During a full opposite lock slide for example, it'll be rather high for the rear tires regardless of compound.
Yes, I am usually at VIR quite often. However, not in the coming months as I have another baby on the way. In fact, I had to cancel for this weeks race at VIR.
But if we are at VIR at the same time (or any track) and I have time I'd be happy to jump in the car with you.
You would need to countersteer when you exceed the traction limits of the rear tires first and have excessive yaw angle (oversteer) - but you will still have some slip angle - just the rear slip angle will probably be greater than the front. However, you can also exceed the traction limits of the front tires first (aka understeer) [again you will still have some slip angle, just the front will probably be greater than the rear]. Both situations illustrate exceeding the tires limit and that you are "pushing hard," although the method for correction is typically different.
-td
Hey, Dell. Just wondering what books you have found helpful. I've got the Going Faster book by Carl Lopez, which is very helpful. Anything else that you recommend?
I know that nothing really beats getting instruction, but I am kind of tuition challenged for the time being.
The best book series I have read is Ross Bentley's Speed Secrets. What I have found is that while you are correct, nothing beats good instruction, the book allows you to have in your mind what you want to translate on the track. There are several sections that I like to read before a race weekend. Really gets me in the right "mind set".
Hey Ahmet, thanks for sharing the video. It's hard to tell with the video, but it looks like the track is especially slippery. I've never driven a track in the rain, but it looks like you kept it straight.
Obviously we're driving street cars so there are some limits....
