PSE quiet from 28mph - 44mph?
Is there a way to stop the flapper from closing during this MPH spread? I assume it's so that it's quiet when you are going through neighborhoods, but I don't like it.
I don't want to pull the vacuum line from the flapper and plug it, as I want to be able to use the button on the dash, in case I want to quiet it down when I have a passenger in the car.
Is there any way to do this?
Thanks,
- Anthony
Thanks,
- Anthony
You could try this: http://www.renntech.org/forums/index.php?showtopic=2470
I snipped the little diode wire inside the box. Button still works. No code or lights or anything. It just works. Great mod, definitely would never ever ever need to reverse this IMHO.
+996
Previous owner did this hack prior to my arrival. I see no reason to ever reverse it. It's only there because of noise restriction laws in somewhere like Sweden or Denmark.
Ok, I just registered on Renntech and cutting the diode seems rather easy, and I don't see why I'd ever want to reverse this. Getting to the back of the relay board to remove the speed sensor wire may be a bit more tricky, however.
I wonder how much a new relay costs if I ever decide to replace this. Probably $100 or so...
