litronic conversion
7th Gear
hello everyone, i have a 99' c2 with hologen headlights. i have a chance to take the parts i need from a 2000 boxster with factory litronic headlights. could anyone tell me what other parts i may need i have already removed the headlight pods and wiring harnesses. i would like to keep the hi beam and ignition on dip feature. i realize i will not be able to keep the self level option. any help on where the module is located and how to wire up would be of much help.
In the 2000 996, the control unit you seek (called the AHVAC) is located at 6cM in the diagram below. No idea if it's the same for the Boxster, but it's a start. You might think about grabbing the two ride height sensors and fabricating your own wiring between those and the control unit.
