996 Forum 1999-2005
Uneven wear on rear tire normal?
Old 05-18-2009, 12:14 PM
BimmFiniti
BimmFiniti's Avatar
Default Uneven wear on rear tire normal?
I'm seeing a significant difference in wear pattern on my right rear tire:
* The inside tread is much more worn down than the outside.
* The wear pattern on the other three tires looks much more consistent, including the other rear tire and the right hand front.
I expect to have my rears wearing faster than my fronts, but the uneven tread wear pattern on a specific tire has me worred. Is this normal? Any advice on this? Thanks!
Old 05-18-2009, 12:17 PM
yasuro
yasuro's Avatar
yes it is normal. it has to do with the negative camber in the stock setup.
Old 05-18-2009, 01:12 PM
BimmFiniti
BimmFiniti's Avatar
Thanks for the reply. So, this is only on the RHS? I don't see it on the left rear tire.
Old 05-18-2009, 01:13 PM
BillJ
BillJ's Avatar
If you have uneven wear on one side of a given end then your alignment is suspect. Get it checked.
Old 05-18-2009, 01:17 PM
frankfast
frankfast's Avatar
Is it a C-4? I have the same problem. My right rear needs replacing but the others have a few miles left on them. I don't think it's a camber issue but I'm curious to know if you've got a C-4.
Old 05-18-2009, 02:08 PM
yasuro
yasuro's Avatar
my C4 wears evenly in the back. sounds like a suspension setup problem.
Old 05-18-2009, 02:10 PM
yasuro
yasuro's Avatar
oops. read it too fast. it is not normal wear.
Old 05-18-2009, 04:42 PM
BimmFiniti
BimmFiniti's Avatar
No, it's not a C4.
So... it's normal to expect uneven wear on the rear tires due to negative camber, but both wear patterns should be similar?
Old 05-18-2009, 04:58 PM
yasuro
yasuro's Avatar
yes. the insides of the rear tires will wear more quickly than the outside, but both rear tires should wear evenly.
Old 05-18-2009, 05:12 PM
Blackness
Blackness's Avatar
My 2000 C4 is wearing more on the inside right as well. I had an alignment when the tires were installed. I'm guessing that somehow it got knocked out enough to cause this. I can't imagine it's supposed to wear more in the right due to alignment spec.
Old 05-18-2009, 05:58 PM
DCP
DCP's Avatar
My C2 right rear went the same way. I was told that uneven wear was due to acceleration torque, but I have no real idea whether my alignments were done correctly, or stayed true.
Old 05-19-2009, 07:16 AM
frankfast
frankfast's Avatar
In a C2 is the right rear the drive side? That would account for the wear. But in a C4, how is the power distributed in dry conditions?
Old 05-19-2009, 09:59 AM
caribbeantech
caribbeantech's Avatar
mine always wear out unevenly but I always figured it was the way I drive the car...
..I slide around and punch it in the curves...and I favor one side much more...
...I swap them over at about 5,000 miles to even it out...
Old 05-19-2009, 11:55 AM
BimmFiniti
BimmFiniti's Avatar
Can you swap the rear tires from side to side? On my other car, which has PS2s, the tread is directional and asymmetric, so I don't think I can swap left and right rears. My 996 has Proxes T1-Rs (unfortunately); not sure about them.
Old 05-19-2009, 03:09 PM
caribbeantech
...you take them to the tire-guy...and 20 bucks later all is swapped...
they are quite familiar with these requests...
however, Sumi III's are not directional, so I can 'just do it'...they are just marked 'Outside'...
(albeit, NOT N-Rated though...)
Quick Reply: Uneven wear on rear tire normal?
