Time for and updated baby seat model thread? Past threads have outdated names, etc.
#466
I snagged the '16 Diono car seat from my wife's '14 Audi Q5, and while it does fit in the back of my '99 996 Cab, it's not a perfect fit. It does work though, and this Diono is one of the safer, slimmer seats that claims to allow up to 3 installed side by side in our Q5 (which is not a large SUV - similar to a BMW X3).
However, I'm considering an IMMI GO instead. Has anyone tried this in a 911 Cab? Looks like it's even smaller and meant for short trips, because it's not all that comfortable.
https://www.immigoseat.com/product/immi-go/
#467
My kid just turned 3 years old @ 38" & 31 lbs
For 2+ year, he sat in a Combi Coccoro (first rear facing behind passenger seat, then forward facing behind me) in my 99' 996 without any problems.
But his height has outgrown the Coccoro, shoulders above the highest harness hole.
Today, just picked up a Evenflo Stratos (from Toys R Us for $129 MSRP, side tip - they just started a promo to trade your old infant toddler car seat and beds for 25% off car seats and furniture). The base is exceptionally narrow on this seat, so no problem using it on top of the seat cushion. I had a difficult time getting it to tighten down on the seat using the forward-facing seat belt holes. But read a tip to use the rear-facing seat belt looping holes instead, and the whole thing tighten down absolutely perfect. FYI, I also use the top tether. Can't wait to put the kid in it tomorrow. Hope this helps others.
#468
Installed a Cosco High Back booster car seat last weekend (I had previously used this in the 993). No issues with fitment in the 996, though removing the bottom seat cushion gave my 6 year old daughter additional headroom.
I used the rear latch under the carpet to secure the seat.
I also tried removing the fold down seat back, but was not comfortable with the fact that this allowed the booster seat to lean back quite a lot. IMO, the seat back provided some additional much needed support.
#470
Thanks - great advice and comments. I had experimented with rotating the seat belt latch aft of its normal position with some success, but the seat still moves too much. But it made me think that I could potentially achieve better results using an old fashioned lap belt on the factory mounting points - like this (I noticed someone else mentioned that in an old Rennlist post):
I think the advantage of this is that I will be able to cinch the belt tighter given that the mount points will be well beneath the seat on both the left and right sides. For the record I ordered it here:
http://www.retrobeltusa.com/product-p/2p-xxx-eu60.htm
I'll also try the high density foam for positioning.
I'll update this thread with results.
Regards,
Michael
2004 911 4S
PS - can someone confirm the Brey Krause part number BK-9003? I'd like to hedge my bet on the lap belt by also preparing to use the latch mount system like this chap did:
https://rennlist.com/forums/964-foru...hild-seat.html
Regards,
Michael
2004 911 4S
Can you fix those attach on both side of the seat?
#471
I've just gotta make it to the booster seat phase...hopefully better then.
#472
Exactly. My 5 year old hates driving with the top open. The blowing wind is very loud for them and the backseat gets significant turbulence.
I have the Maxi Cosi Rodi, it has a narrow base and fits in the rear with the seat and back cushion removed.
I purchased a cab thinking it would be fun for my toddler daughter. The irony is that it is the worst variant of the 996 you could get for a car seat. No rear latch and you lose a couple of inches to the pop-up bar housing. Having an adult in the front seat is not advised if you've got cab and a normal length toddler. Oh, and the kid gets tired of the wind blowing in her face fairly quickly.
#474
Unless you can fit a rear facing seat in your car it's gonna be awhile, I didn't take either of my little ones for a ride until they were about 18months old. I have a full size fwd facing Maxi Cosi Rubi seat.
#475
#476
#477
The Diono is pretty much it for Cabs without the top tethers. For my 5-yr-old, we're using the BubbleBum Travel Car Booster, since she's quite a tall girl. I've considered RideSafer but I cannot find many independent reviews on it, so I'm not sure I want to do it.
#478
#479
Safe traffic
I use Safe traffic ride safer travel vest in conjunction with a Costco booster or a bumblebum inflatable booster.
the vest almost acts as a 5 point harness while using the seat belt.
#480
I think the product is a great idea, especially compared to a regular seatbelt, but compared to a child safety seat, it doesn't seem to pass muster.
