996 Forum 1999-2005
ceramic brake pad question
Old Jan 30, 2009 | 04:38 PM
yasuro's Avatar
yasuro
Default ceramic brake pad question
if i were to put on ceramic brake pads with stock rotors, does it shorten the life of the rotor?
Old Jan 30, 2009 | 05:39 PM
deckman's Avatar
deckman
I don't know the answer to your question, but why are you considering ceramic, brake dust?
Old Jan 30, 2009 | 07:37 PM
medtech's Avatar
medtech
I know I'm considering ceramic b/c of brake dust. I have ceramic on the Cayenne and I love it.
Old Jan 30, 2009 | 09:04 PM
Macster's Avatar
Macster
Default Better question might be does using ceramic pads with iron rotors..
even work? Is this combo even supported? I think not. But you need to know for sure.
Sincerely,
Macster.
Old Jan 30, 2009 | 11:05 PM
yasuro's Avatar
yasuro
yep brake dust. i don't track the car, so it isn't for performance. when reading other threads about ceramic pads, it wasn't clear on whether or not it required special rotors.
Old Jan 30, 2009 | 11:30 PM
yasuro's Avatar
yasuro
here are the pads i'm considering: http://www.tirerack.com/brakes/resul...&brand=Akebono
Old Jan 31, 2009 | 03:04 PM
Macster's Avatar
Macster
Default Hmmmm. Interesting. Apparently the ceramic pads are intended to work...
with iron rotors. Do you know if pads will work with stock/OEM cast iron rotors or are aftermarket special (?) iron rotors needed? I could find nothing on the site that stated this.
Next brake job I could see switching to these pads. The current set turns my car's wheels black with dust in just seconds after wheel cleaning. Worst brake dust output ever.
Sincerely,
Macster.
Old Jan 31, 2009 | 03:59 PM
LVDell's Avatar
LVDell
Those look very promising if they "work" properly at the levels needed for the car. The price is attractive as well. Keep us posted.
Old Feb 2, 2009 | 12:40 AM
yasuro's Avatar
yasuro
i plan on getting them this spring and i'll keep the board updated.
Old Sep 4, 2015 | 12:18 AM
Nathan Lewis's Avatar
Nathan Lewis
This is an old thread, but does anyone know if these Akebono ceramic pads do OK on the iron rotors?
Old Sep 4, 2015 | 05:14 AM
targa996's Avatar
targa996
Default Akebono
I used akebono on my bmw e46 ... Much less dust and light color so you can't see it .. Akebono says also wears rotor less - I'm running stock zimmermans - after 30k miles pads still look like new and in the same time I've almost worn through a set of stock rears - only downside is less bite from cold - not a problem but you do notice that. Not sure about high temp track performance either - but if you're going to do that you should probably be looking at high carbon content pads
Old Sep 4, 2015 | 07:33 AM
Jason @ Paragon Products's Avatar
These pads are made for steel rotors, not PCCB so use on steel rotors is their intended purpose. There's a couple inexpensive ceramic based pads on the market now.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old Sep 4, 2015 | 09:24 AM
Joe Ricard's Avatar
Joe Ricard
Before you buy pads for your car do some Research. Most sites have the ability to compare this pad against that pad and also provide intended use. Endurance, track HPDE, Autocross, street, hard parking .
Old Sep 4, 2015 | 10:46 AM
alpine003's Avatar
alpine003
Bingo. There seems to be massive confusion on this thread started by a newb.
Old Sep 4, 2015 | 10:16 PM
dmw996's Avatar
dmw996
I just put Akebono on my Lexus IS300 (with Supra rotors) as a 'trial' to see if I wanted to try them on my 996. I'm not impressed with the bite at all. Ceramic worked well on my Tundra.
I'll do either factory Porsche pads or Hawk HPS. I did Hawk HPS on my VR6 Corrado (with MK4 GTI rotors/pads) and they do a real good job.
