996 Forum 1999-2005
engine issue
Old Jan 1, 2009 | 02:09 AM
wahoo911cab's Avatar
wahoo911cab
Default engine issue
Own a 99 cab with 72K miles (and manual trans) which has run great for the two years I've owned it. It has had the RMS replaced. For the last month I've noticed that when I step on the gas with any force the TAC climbs quickly but there is a noticeable lag in power. The engine sounds and revs just fine. Any thoughts what that could be? much appreciated.
Old Jan 1, 2009 | 04:11 AM
Michael-Dallas's Avatar
Michael-Dallas
clutch
Old Jan 1, 2009 | 08:43 AM
Barn996's Avatar
Barn996
Old Jan 1, 2009 | 09:33 AM
gota911's Avatar
gota911
Newbies Hospitality Director
+2, clutch is going.
Barn, how is the MO3O suspension different from the M030 suspension?
Old Jan 1, 2009 | 11:05 AM
Jon996's Avatar
Jon996
+3. Mine was just replaced. Same symptom you mentioned.
Old Jan 1, 2009 | 11:13 AM
ivangene's Avatar
ivangene
Parts Specialist
Old Jan 1, 2009 | 12:02 PM
Chaos's Avatar
Chaos
Not cheap but it helped mine quite bit also !
Old Jan 1, 2009 | 03:29 PM
Barn996's Avatar
Barn996
Tim- My USM030 doesn't lower my 996 at all, but the ROW(rest of world) does slightly, but not as much as PSS9 or other coilovers. I believe the front and rear bars are the same however.
Old Jan 1, 2009 | 04:35 PM
gota911's Avatar
gota911
Barn, I guess I should have been less subtle and asked "how is the "M oh-3-oh" suspension different from the "M zero-3 zero" suspension?" I had noticed you had used the letter "O" instead of the number "0" when listing the suspension in your sig, so I was giving you a little poke in the ribs!
Old Jan 1, 2009 | 07:26 PM
Barn996's Avatar
Barn996
Oops, didn't even catch your clever distinction of the 0 vs O. One is slightly 'rounder' than the other. What a tough crowd!
Old Jan 1, 2009 | 07:32 PM
russo's Avatar
russo
Definitely the clutch, been there, done that. Prepare yourself for a $1500.00
replacement if done by the dealer.
Old Jan 1, 2009 | 08:12 PM
gota911's Avatar
gota911
Well, picking on the Newbies is like shooting fish in a barrel, so I thought I would look for something a little more challenging!
