oil in coolant overflow ....?
but no coolant in the oil ? shes a 1999 996 C2 with mileage in the high 60's. I've heard anything from cracked head, cracked block, and cylinder sleeve slipage, to heat exchanger (oil cooler) ? ANY IDEA'S OR EASY WAYS TO DIAGNOIS THE PROBLEM ? NO ENGINE LIGHTS, NO LEAKS, NO SMOKE, AND HAD A FRIEND PUT A SNIFFER IN THE TAIL PIPE AND ALL READINGS WERE PERFECT ?!?!?!
Could also be head gasket. Do a leak down test to be sure. This is different from a compression test.
http://en.wikipedia.org/wiki/Leak-down_tester
I would probably flush my coolant first, and see if oil returns. What is more common with a problem of this nature is excessive pressure in the coolant lines, caused by exhaust gasses leaking into the coolant system and adding additional (excessive) pressure.
Given that it's a '99, there is a 'history' of cracked heads on the early M96 blocks
http://www.autofarm.co.uk/pdf/Total911_July06.pdf
Best of luck!
“The next things to be concerned about are cracked
cylinder heads”, says Steve. “The mounting point for the
hydraulic tappets is a weak point,” he explains. “The
head can crack from the bolted face across to a core
plug. This leads to oil forcing its way into the water
jacket.” So look out for tell-tale signs of contamination in
the coolant. Steve says that they have crack-testing
equipment and examine every head they take off, as a
matter of course. Interestingly, he says that they only ever
find cracks on left-hand heads, even though the castings
are identical. This could well be down to the way the
coolant circulates around the engine.
Best of luck!
