Triangle, NC Members: What's Your Favorite Track Shop?
I need to get a corner balance and spec alignment done on my '99 C2 after installing a gt3 suspension myself. I assume while they are doing corner balance they can also set the car up with my desired ride height. I know european has a very nice alignment machine, but the operators make the difference (i once had someone toe IN my car rather than OUT; mixed up + and - values). I also don't think EP can do corner balance.
Previously I used performance chassis (see above toe issues) on my M3, but I'd like to find a more porsche specific shop this time around.
Also, while we're on the topic, please comment on my street/track alignment or add your own. I am basing most of this off of mixture of what i've seen on the forum, heard from other members, and experience in my M3.
I would like to run less camber and probably request -2.0 front and -1.8 rear but otherwise stick with the stock GT3 settings...
Front Axle
ride height 115 mm
Toe Unpressed (total) +5'
Toe difference angle at 20deg lock -1º 20' ± 30'
Camber (with wheels in straight-ahead position) -2.5º ± 5', max. difference, left to right, 5'
Caster 8º ± 30' (same as stock), max. difference, left to right, 30'
Stabilizer setting 4 (1=softest/outermost) (same as stock)
Rear Axle
ride height 128 mm
Toe per wheel +35' ± 2', max. difference, left to right 5' (same as stock)
Camber -2.3º 50' ± 5', max. difference, left to right 10' (same as stock)
stabilizer setting 4 (1=softest/outermost)
ride height 115 mm
Rear Axle
ride height 128 mm
Dan. What tires are you going to be running at the track?
I'd go closer to 0 toe at the front. I actually run toe out a bit at the track. Tires are going to help determine more where the camber should be. If you're running street tires I had pretty good sucess with -2.0 both front and rear on sticky street tires. our spring rates are a touch different so it's tough for me to say for sure. Paul_996 has basically the same setup as you and tracks quite a bit...I'd bet he's got really good info on where to set things.
Andy
Andy
I'll prob end up going there, and just request mark to do it.
I need to get out and go to sunday coffee and bagels thing sometime soon. Probably next week when I have the parts on.
You really should, it is a great time and a lot of p-car knowledge amongst those that attend. Plus the post coffee drive is always a plus!!
