MK1 Muffler Rattle - Internal Repair
I have been dealing with a very annoying rattle from the passenger's side muffler on my 2000 C2. These mufflers have an inlet tube, a crossover tube, and an outlet tube that work together with the three chambers to muffle the exhaust. I used a plasma cutter to open an access panel in the outboard side of the can and found most of the welds had fatigued and failed. The crossover tube was loose and causing the rattle. I used a mig to re-weld the tubes and then a tig to reseal the access panel. Attached are a few pictures for reference in case others run into a similar problem.
-Wayne
-Wayne
CLK911 (09-29-2020)
How has your repair held up? Looks like a nice job but I don't have those tools.
I have the same problem on my '00 C2 as well (driver's side). I am buying one used muffler from eBay for $90+40 shipping = $130. The "donor" muffler has 52k miles on it. Junkyards are quoting $175-185 shipped for one muffler, FYI.
pictures of a mk2 muffler cut open ?
I am about to do the same on my mk2 with pse mufflers and was wondering if anyone had pictures of similar jobs done on mk2 - even pse! to make sure I don't cut the wrong place.
thanks,
pierre
thanks,
pierre
