996 Forum 1999-2005
Drilling hole in muffler to let out moisture. Have you done this?
Old 08-26-2008, 04:20 PM
befast
befast's Avatar
Default Drilling hole in muffler to let out moisture. Have you done this?
Some time ago someone recommended creating a small hole at the bottom of a muffler to let out excess moisture. Idea was to prevent rust on the inside. Is this nonsense? Seems iffy, especially with salt getting into the inside of the muffler in the winter and making the situation worse.
Old 08-26-2008, 04:28 PM
LVDell
LVDell's Avatar
What about that big opening at the exhaust tip?
Old 08-26-2008, 04:31 PM
Tippy
Tippy's Avatar
Ok, that was pretty friggin' hilarious.......
Old 08-26-2008, 04:34 PM
chsu74
chsu74's Avatar
What's the suggestion for tractors with their exhausts pointing straight up during a rainstorm?
Old 08-26-2008, 04:35 PM
LVDell
LVDell's Avatar
Park 'em in the barn silly.
Old 08-26-2008, 04:36 PM
Tippy
Tippy's Avatar
They need one of those cool flapper valves that bounce at idle.
Old 08-26-2008, 04:42 PM
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
The muffler on my 89 GT actually came with a weep hole in it.
Old 08-26-2008, 04:50 PM
ivangene
Parts Specialist
ivangene's Avatar
a coffee can also works to cover the hole while it rains... but I think it blows off if the motor is on...(unlike the flapper thing) ? or does it mix the water and make coffee ala' exhaust pipe ?
Driving the car seems to push the water out, I live in Seattle and if I had a tiny hole in my muffler it would fill up while parked as that is about where the water line is in most places....
E
Old 08-26-2008, 04:53 PM
Steven C.
Steven C.'s Avatar
Only if you want your car to sound like it's spitting all the time AND you want to rust the muffler out even faster
Old 08-26-2008, 05:15 PM
htny
htny's Avatar
oh I'd kill for a set of those
and fire
need fire
Old 08-26-2008, 05:19 PM
chsu74
chsu74's Avatar
Drive the car more often and you should encounter less car issues as a whole. Once the car runs for 20 minutes the muffler should get hot enough to evapoate all the moisture that is in it.
Old 08-26-2008, 05:22 PM
htny
htny's Avatar
+1 that's the real advice
Old 08-26-2008, 05:26 PM
Tippy
Tippy's Avatar
How cool would those be on a 996?
Old 08-26-2008, 05:59 PM
befast
befast's Avatar
Haha.... I knew I'd get hammered for this one. I drive my car lots, so no worries there. The root of my question was with whatever residual there might be once the engine is shut off. I guess the answer is no!
Old 08-26-2008, 06:06 PM
chsu74
chsu74's Avatar
and fire
need fire
you mean flames (fire) on the side of your pcar.
Quick Reply: Drilling hole in muffler to let out moisture. Have you done this?
