Wierd Air Conditioning Issue
compressor & refrigerant systems are fine (checked w/ guages). the fan works fine. the problem is that the system blows luke-warm air. i suspect the system is mixing hot air from the heater coil with cool air from the evap coil. the heater seems to work fine & i can adjust its temperature.
i think the culprit is one of three things:
1. climatronic unit
2. one of the flap servo motors (not sure which one; there are like four)
3. on of the seals that seals the mixing flaps closed
i DO have little pieces of seal blowing out of my vents; maybe it's related? has anyone experienced a similar problem? it's HOT!!!!! thanks in advance.
1. climatronic unit
i took the A/C fan out under the passenger footwell & put my hand on the evap coil; it is FREEZING cold.
