Code Reader Erase Failure - Anyone else have this issue?
I have a CAT that seems to be having issues (or maybe the O2 sensor). It trips a CEL once in a while - maybe once a month or two or three. Anyway, after a few trips, it resets and the CEL goes off - until the next time.
So I decided to get a code reader to check the code when it happened, so I don't have to run to the dealer every time. If it's the same code as always, I want to reset it to be sure I'm not missing something else causing a CEL. Neurotic, but so what. The car will be in the shop to fix the offending part soon enough.
I got a Cen-Tech 94217 Code Reader at Harbor Freight (http://www.harborfreight.com/cpi/cta...emnumber=94217). This appears to be a rebadged Autel Geniscan GS400 (http://www.auteltech.com/gs400.htm). Everything is the same, right down to the manual.
Now the kicker, it accesses the car, reads the codes and displays them. I had a P0420 code. BUT, when I try to erase the code, I get an "Erase Failure!" message. I'm guessing that this is the reader, and not a Porsche specific issue.
Any thoughts? I'm going to redo the scan an clear tomorrow, but looks like I'm gonna return this one and switch to another manufacturer. Maybe Actron. Or just pony up for a Durametric.
Please let me know if you've had any issues erasing codes, and in particular if your scanner clears P0420 without issue.
-td
MY00 C2 Coupe
Appears to be DME 7.2
-td
MY00 C2 Coupe
-td
MY00 C2 Coupe
-td
MY00 C2 Coupe
I use an Actron model, the model number escapes me.
When I go to clear a code my Actron puts up a caution about shutting engine off but turning key back on before pressing button to clear the codes.
I've never bothered to do this and have never had any problems clearing DTC (error codes -- including 0430, 1117, 1128, 1130, 0156 and several more) with engine running.
But maybe your car's different?
Sincerely,
Macster.
Not had this issue either - have always been able to erase codes and reset the CEL - I have the same reader as you from HF
You sure the ignition switch is in the right place to allow OBDII access?
1 Post
Hmm, sounds like you should just try a Veterinarian. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The only time I've had problems with my reader (which is just the basic $80 autozone version) is if I had the key turned to the incorrect position.
The only issue is that the reader gives an erase failure message when I try to reset the CEL light.
Sorry it wasn't clear that the machine is actually accessing the car and retrieving data.
-td
As I mentioned in the original post, I can access the car and get the fault code P0420 from the reader. In addition, I can see freeze frame data for the fault. The car is not running, but it appears that the two clearly communicate.
-td
-td
Turned out that the reader had the old ones stored, and had not accessed his car at all!
Worth checking...
I had this happen if I connect the scanner after turning on the car or putting the car into ACC. Plug in the scanner first. Then move the key to the ACC, read the code and clear it. See if that works.
15 year old thread lol
Norocehcap (12-27-2023)
