C4S - Front Differential Removal DIY
Hi all,
well, I've searched the archives and I can't find a DIY related to removing the front differential on a C4S. I have a "grinding" noise that I've localised to the differential and my local mechanic has confirmed that it is indeed something internal to the differential but he wants big bucks to remove it to find the source of the problem. I'd rather do this myself (because I'm cheap ) so can anyone point me to a DIY on how to remove it?
Thanks, Ron
Thanks, Ron
You can remove the driveshaft first and see how you like it. Driveshaft removal will only take about 30 mins and require no other modification.
If you like it, you can then continue to remove the front diff and components.
I removed the driveshaft and PSM was interrupting way too soon and too many times. In fact, I felt as if I could have taken the corners faster with AWD even with PSM instead of RWD w/ an PSM that is programmed for AWD.
You can turn PSM off and THAT is complete fun.
