Tiptronic will not go into drive !
My 99 C2 coupe Tiptronic. Will not go into drive.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
No CEl or flashing drive letters. no codes when I used my ODB II reader
I am able to put it in reverse and she moves normally.
No symptoms before. no slipping or leaks or anything strange.
Drove home Friday, parked normally, not driven on Sunday. now not going into drive.
Some questions:
What causes the lock out of drive ?
Is this a mechanical problem ?
a fluid level problem ?
Some questions:
Pure speculation, just so your post gets bumped and someone smart can read it...
The last time this happened to me on a vehicle, it was the brake/shifter interlock switch that failed.
Good luck!
Good luck!
It will not physically go into D. Acts like there is physical blockage or linkage problem ?
It seems that if the bands are bad or something like that it should at least get the lever into the D position.
I tried to copy the manual for it but it is encrypted, sorry. Although I never replaced mine, it looks very simple to get to and replace.
You may want to for the time being, is to just remove it so you can drive your car until you replace it.
Right on the money gentlemen. Most Excellnt calls ! The switch is ok, but some thing had dislodged and was blocking the detent.
I am taking this as a sign from the Porsche Gods to go get the fluid changed and a couple other minor things fixed at my favorite Indy. Since I am off work the car is now at the shop ...
Whew.. At least I dont have to get a new transmission!
I recommend you also buy it a present. I find that Porsches respond well to positive reinforcement.
Hi guys (and girls!)
I have a 964 C2 Tip that went funny last week when she hopped out of drive and revved like the clutch was slipping...
but as there's a tip gearbox no clutch (as we know it )involved...Car goes into reverse ok, so I presume this means gearbox not SNAFU...but won't engage drive. Any ideas?
HELP!!!
Colm Galway,Ireland
HELP!!!
Colm Galway,Ireland
Yes, but you have a torque converter which is an automatic fluid clutch (more or less)
Hi there!
Right Chris,but you see in Ireland Auto gearboxes are a novelty...not a lot of 'em about. So does the torque converter need fluid to function? I have to plead ignorance here...and what was the detent referred to in one of the previous posts?
Cheers,
Colm
Cheers,
Colm
Just because you have one doesn't necessarily explain why you would be jumping out of first though. It's not a user serviceable part and not the greatest idea to try and diagnose or DIY and auto transmission. You could check the fluid level though. Low fluid will result in no transfer from engine to gears.
