I found out where my coolant went.
#46
Team Owner
Would it make sense to have your oil analized to verify that it contains coolant, before you conclude engine failure? Lots of helpful advice on this board. None of us want another engine failure post since we all share Porsche ownership. Hope it turns out to be something else. GL.
#48
I told a friend of mine about my dilemma. He asked why not just replace the head gasket or head, depending on which one broke. Why is that not possible?? Just curious why the motor has to be replaced. It seems that if it's a rebuilt motor, then someone should be able to "rebuild" the head or gasket by replacing with a new one.
#49
#50
#52
Does anyone know if this is the case?
#53
Do an oil change. Flushed the oil into a clear container. Oil/water don't mix so it will separate once it settles. Top of the coolant.
Hopefully you just prematurely came to an conclusion it is a blown engine.
#54
As a casual observer, it sure appears that the cars that live the lives of garage-queens (those that come out on weekends and have less than 10k on their tickers) are the cars that are having most of the problems. Am I dreaming this? Anyone else see this trend?
C.
C.
#55
He has a 2000 w/60K miles.
I have read and know of many that never got a chance to be a garage queens before the engine let go during a period wee the miles were low giving an impressions of yet another low mileage 996 goes down.
The more you drive them the better, no argument on that w/any car
Hard not to reach for something in the quest for solutions. It would be great to be able to come up with a list of don’ts and eliminate your risk, problem solved.
No such thing
It starts with a good purchase followed by good driving/good maintenance. Then you hope for the best.
To worry takes away from the enjoyment w/nothing good to gain, easier said than done
#56
We need better pics. 1st pic looks bad but the 2nd looks fine, but it is hard to tell. There is no doubt when I have had coolant in the oil of other cars, it was a light brown or tan color. I personally would run the car for at least 30 minutes to an hour (hard and high RPM) and see if all that condensation burns off the oil filler tube. If it does it is fine.
#57
This post is getting funny, the guy hasn't even bothered to properly analize the problem, and he won't listen to anyones advice .. very odd if you ask me ....
#58
The picture of the oil filler tube looks like many do after a winter season without extended driving periods. Water vapor, condensation, etc. gets in the oil and never gets totally evaporated off. You need to drive a car for an extended period, 30 minutes or more at full temp to "burn off" the water. Both my car and my business partners car had similar looking "sludge" when we changed the oil this week, but the engines were fine.
Now the fact that the oil level went up is somewhat suspect. It will be interesting to see what happens. Also, take a look at the coolant in the tank to see it is contaminated.
#59
Given the loss of coolant, the rise in oil level, and the choc looking gunk, it's an intermix failure.
Then you look at the MY of the block, and you have the design/QC issues from that era that have been seen, again and again, to give a higher than acceptable rate of exactly this sort of failure.
It's nothing to do with how it was driven - it's a design and factory QC issue on the M96 from that era.
Do the research and go after Porsche if you have the stomach for a fight - people have been given new engines out of warranty, given that they present their case well, and are informed as to the 'know issues'.
Other than that, you're looking at a new motor - if this diagnosis plays out.
There is no way I'd put my $$$ behind a pre 3.6 motor - just too much risk.
#60
Garage queens and intermix - no case what so ever, it's a design/factory QC issue pure and simple. You bought a time bomb and it eventually went off.
