I found out where my coolant went.
#31
Othomasjr
Very sorry to hear this, there has been a wave of **** lately
Nobody likes to get burned twice, I agree w/you here. The thing is you are not fully burned as BC stated, game not over yet.
Take a little time, that will not cost you further.
You have taken an unfortunate financial hit regardless of the direction you take, as you know, sad but true.
I would suggest you do some research, like calling the dealer asking for any assistance, quotes, etc...
Once you get all the numbers crunched make your move on if it is worth it to you or not
Very understandable which ever way you go, tough call
GL to you
GL to you
#34
Had you ever checked the oil level since you bought the car before this time? I'm sorry, but everyone is jumping straight to the new engine conclusion and I'm not convinced. You may have a situation that your oil was over filled. There can be lot's of reasons why your water level is low other than catastrophic failure.
Get the car towed to the dealer in the morning and have them tell you what it is.
#35
Yes, I've checked it several times since it's been changed. It was always right on the button on the dipstick, even though the gauge on the speedo sometimes said it was a touch low. Now, it is MUCH higher than it ever has been.
#36
Do what Deckman said
"I've been low on coolant before, in fact I just topped it off today. In addition, a couple months ago I panicked when I started the car and a big puff of white smoke came out. I open the oil fill cap and found what you found: yellow shmegma. I thought the worst but people here suggested it was water vapor mixing in with the oil caused by not letting the engine come up to full speed on short trips. It's ususally burned off. "
it is a terrible photo but your dipstick oil looks okay, I think you are over reacting, at least take it to a shop and get a proper diagnosis,
#41
No offense intended here, but do you have enough information (and experience) to accurately conclude that the engine is blown. I'm hearing that the oil level seems high but you're not sure if the oil has coolant in it.
If you're not sure the engine is blown, how can you make decisions about selling the car? If it isn't blown, and you sell the car thinking it is, aren't you make a huge mistake?
Don't you think at least an inspection (and diagnosis) by a mechanic is called for?
#42
I tend to agree. A PPI will catch existing problems; however, it is not a predictive process.
#43
This is a good point. The hit you would take on selling the car without an engine would certainly justify having the car inspected.
#44
Would it make sense to have your oil analized to verify that it contains coolant, before you conclude engine failure? Lots of helpful advice on this board. None of us want another engine failure post since we all share Porsche ownership. Hope it turns out to be something else. GL.
#45
I'm sorry. I think my writing wasn't giving a true idea of what I plan to do. I have a good dealer that will pick cars up and trailer them for service. I FULLY intend to have it checked out before I go off half-cocked and sell it. I just know the history with these motors and was venting a little I guess.
I will have it checked by my P dealer and then go from there.....probably will choose not to replace engine if that is indeed the culprit. Will just sell it instead.
Thanks!
Thanks!
