Transmission Oil drain plug?
I'll be changing my transmission oil soon and want to confirm I have the right tools. Anyone know for sure if the transmission drain plug on an '03 C2 manual transmission is:
16mm Triple Square
or
16mm Allen
Also, the fill plug is 17mm Allen correct?
16mm Triple Square
or
16mm Allen
Interesting that this DIY states 10mm versus the one on RennTech which said 17 & 16mm. 10mm would seem to make more sense, so I'll go with the one you provided. Thanks Red! See you on the Rennlist NY Tri-State 2nd Annual Spring Run (4/27)?
Hello,
I just did this (this weekend) on my 99, and it's a 10mm. I had to use Vise-grips to 'break' the drain plug loose then used the 10mm Allen. No real problem. I thought that the 22 ft lbs was kind of 'soft' for the torque, but that's what I used (the factory must have used 80 to 100 ft lbs). I also put in "just" 2.7 Ls instead of 'until the fluid comes out the hole'.
Hope this helps,
Patrick
Hope this helps,
Patrick
993 had 17 and 19mm!
It is indeed only 10mm for both. Make sure you get a decent length breaker bar and an allen socket set - using the hex keys are a bad idea overall when you are dealing with something as delicate as these drain plugs. You likely know this already but make sure to open the fill plug first
Of all the 993s I wrenched on I never had to use any 17 or 19mm allen, As I don't even have those two size in my chest.
Patrick
Did you go with Red Line? I've been pleased with mine. I haven't missed 2nd gear since the transmission change. I can now go up the gears comfortably even when the tranny's cold.
Yes, Magilla Gorilla is alive and well and tightening transmission drain plus at Porsche in Germany!!
Always best to check what is on your car - Porsche changes things without notice.
Patrick
Thanks for asking and thanks for telling me about the RedLine oil.
C'ya,
Patrick
It's pretty normal for some fluid to come out when you remove the fill plug because you're supposed to fill the trans until the lubricant comes out the hole, not by some specific volume. Assuming the car is level (carpenters level on the door sill is an easy check for that) of course.
