Steerring wheel slightly crooked
My steering wheel is off to the left by just a little bit when driving straight.
The car handles great (goes straight) does not pull to either side when I let go. Tire wear looks even/normal.
This is not anything like other front end alignment issues I've experienced.
So am I still looking at a simple front end alignment to take care of this?
I HATE when that happens. I am guessing when they did the alignment, someone didn't lock the wheel straight. Then, when they align the wheels, and connect the steering, the steering wheel winds up crooked.
Make sure you're on a level surface, LUD. I know that a lot of our hwys crested up in the middle and if you're living life in the fast lane (left), you're always driving on a not so level.
If it is actually off-kilter, it's a simple adjustment and you should not have to realign the car at all assuming your alignment guy got some skills.
This is usually the result of asymmetric toe in front, and if it wasn't caused by a recent botched alignment, the total toe is probably off as well. In either case, it will need a trip to the alignment shop to correct the problem.
But if the steering wheel has ever been removed for any reason, it might have been improperly replaced.
I appreciate all the info guys.
As far as I know the steering wheel has never been removed. So it sounds like a bad alignment, will take care of it when I find a good place to go.
You are correct about that railroad track effect on the highways, but this crooked wheel thing is all the time Ben.
Thank you
Thank you
i had this happen recently...
go to a good alignment shop and have them "turn the tie rods" an equal amout on each side ......this will compensate the wheel...keep adjusting till right....
this will not throw the alignment off as long as the person marks the bolts and turns them exactly equal on each side..
good luck
good luck
good luck
good luck
