996 water temp question
#61
Originally Posted by Sam-Son;[url=tel:18292087
18292087[/url]]I live in NYC so while that normally doesn't seem like a hot climate when it isn't below zero its 95f with 95% humidity. Lots of stop and go traffic and the car does not seem to care for it. Already have a low temp tstat, clean radiators, new aux fan and relay. The system seems to be working as intended except that even with the low temp tstat the car still runs right to the end of the '0' and the oil pressure dips. I want to keep the M96 as healthy as possible hence my desire to reduce coolant/oil temps. Third rad seems like a good idea for additional cooling capacity for my sprited driving and traffic duties. UAOS with the auto drain is on my list
zbomb (08-10-2022)
#63
Noted. The other half of the concern is while the car is moving it still runs right to the end of the '0' I can't imagine that is great for the oil and more importantly the engine life. Like I said I want to keep the M96 as healthy as possible for as long as possible. Haven't done the AOS yet but have seen none of the warning signs.
#64
End of the 0 is around where the oem thermostat is fully open, so probably not the end of the world. When my cooling system was pretty crapped up I'd be one needle width away from the next unmarked line, but still never got a high temp warning light.
#65
Originally Posted by Sam-Son;[url=tel:18293524
18293524[/url]]Noted. The other half of the concern is while the car is moving it still runs right to the end of the '0' I can't imagine that is great for the oil and more importantly the engine life. Like I said I want to keep the M96 as healthy as possible for as long as possible. Haven't done the AOS yet but have seen none of the warning signs.
The only other thing to be concerned about is oil temperature, but that’s a whole different discussion, and quite frankly, I’m not worried about my oil temps when stuck in traffic.
GC996 (08-10-2022)
#66
For reference, Chicago City stop & go driving on a hot summer day (82F), coolant temp needle is in the bullseye of the 0 in the 180F number. I have a low temp thermostat and my OBD reader says actual coolant temp at that level is 207F.
#67
Originally Posted by Tr4ckD4ys;[url=tel:18296237
18296237[/url]]For reference, Chicago City stop & go driving on a hot summer day (82F), coolant temp needle is in the bullseye of the 0 in the 180F number. I have a low temp thermostat and my OBD reader says actual coolant temp at that level is 207F.
#68
Samson I live in nyc and my temp is always at the 0 end in stopngo
my fluids are new the radiators are newish CSF and have been cleaned 2x this years during service
oil pressure drops to 1.2 when hot but is always 3bar at 3k rpm
#71
Originally Posted by Tr4ckD4ys;[url=tel:18297619
18297619[/url]]At those temps, with the engine running, my idle oil pressure is at ~1.6bar ... with a bit lower temp it typically hovers around 1.9-2.1bar at idle. The radiator fans were definitely on, and if you put your foot down in front of the front tires, you can't keep it there for long because of how hot these things are blowing...
#72
Originally Posted by dporto;[url=tel:18297262
18297262[/url]]It depends on engine rpm. At idle (780 rpm) it’s generally between 1.2 and 2 bar depending on engine/oil temp. There are many variables that lead to this including the oil sender. There are no hard and fast rules to speak of.
