996 aerokit front fitment help *now with pics*
Pocket Sand
would someone be able 2 post a closeup pic of how their bumpers fit on the sides and on the hood area, i'm having some problems lining things up and all the local guys seem to have soso fitment at best.
This is mine which is Porsche Tequipment original. If you go with aftermarket, you could have issues.
Pocket Sand
you wouln't happen 2 have a closeup of the hood/bumper meeting point would you?
i have an OEM, but i think it is off a cupcar because it has the slot for the tow hook. it is polyeurethane tho
what issues are you having? make sure that the **** with the holes on the top of the bumper goes underneath the meeting points on the trunk deck... and push it in real hard till you can put the screws in to hold it in place.
Pocket Sand
i'm going to take it appart and have another look at it. i think the problem may lie with the hood rather than the bumper itself (and those stupid plastic trims and covers that are all over and under the car)
One thing to bear in mind is that you will have to shimmy the bumper position until you get it lined up evenly on either side of the hood.
I had a helper in installing mine and it finally came down to a lot of pressure and pushing to get even alignment on each side of the hood. I'm not convinced that the dealer would have been so diligent if I'd had them do the install.
Pocket Sand
my hood definitly will need some adjustment since i had the hinges adjusted first for a cf hood, then for a stock hood with my gt3 bumper. I don't really want to spend the time to do it myself, how much do you think a good bodyshop would charge just for the fitting and stuff?
Pocket Sand
i double checked the bumper and it is indeed an oem porsche supercup bumper (has the PN on the bumper and the triangle with the P inside it).
i've gotten the bumper to fit properly on both sides, and now need 2 fix the gap between the hood and bumper.
any advice?
![](http://img.photobucket.com/albums/v146/DeAd-EyE/Image011.jpg)
![](http://img.photobucket.com/albums/v146/DeAd-EyE/Image017.jpg)
any advice?
![](http://img.photobucket.com/albums/v146/DeAd-EyE/Image018.jpg)
Pocket Sand
believe me, your car is much better.
my hood and bumper practically touch at the center and get wider towards the edges.
my car had such nice fitment when it was stock..if only i could go back in time :')
Excuse the dirty car on the previous post.
I think if you loosen the screws on the outside and push in to the car and retighten, you'll loose that pull that is making the bumper come close to the hood. That's my thought on it. The trouble I had was that there was too much gap and I had to work the screws located in the trunk area to push the bumper in.
