tips on diagnosing a starter problem?
I got the battery tested, and its fine. So from everyone's input here it seems very likely that it's the starter. I've had an ignition switch go bad, and that behaved very differently, so I'm sure that's not it.
Until the problem gets worse and/or I have some time on my hands, I'll probably do nothing. If it is a starter/heat problem, I'll have to do something before summer temps arrive, so I'll either replace the starter myself or take it to a local garage (any independent recommendations on the SF Peninsula?). I've got the tech manuals, and it looks like a pretty easy task, its more if I want to spend time or money on the problem.
Bob
Bob
My 2000 996 C2 seems be developing an odd starter problem. It cold starts fine, but if I'm running short (1-2 mile) errands, it gets harder to start the 2nd and 3rd times.
The 2nd and 3rd starts are very "slow" to begin, the starter sounds like the battery is almost dead, but if I keep cranking the starter will get its act together after 5-10 seconds and then I'm fine. All lights are at normal brightness, etc.
The problem only occurs after very short drives followed by very short stops. If I let the car cool off more before restarting, there's no problem, and if the drive is longer, there's no problem.
The symptoms don't seem to match a battery or alternator problem, which is why I'm thinking starter motor, but I'm puzzled as to what could be wearing out on the starter that's only a problem when the motor's hot.
Any suggestions?
Thanks,
Bob
Any suggestions?
Thanks,
Bob
Anyway, I had the battery replaced, and this helped, but did not fix the problem. I had a fuel systems diagnostics done and there was no fuel systems issues.
Turns out the starter was just old. I had the starter replaced under my aftermarket warranty and all is right as rain. In fact, in retrospect my cold starts were actually a little slow. With the new starter, it fires up almost instantly whether cold, 2nd, 3rd, etc. etc.
I believe that a new starter plus all labor would have been around $1000. My out of pocket was $50 under warranty.
-td
Just bought a starter off ebay. Hard to believe the price so I hope it's okay. A NEW Bosch for $206, plus shipping. I think I will just give my local mechanic the proper directions and let him take a shot at it. I'm pretty sure he's never worked on a Porsche.
http://cgi.ebay.com/ebaymotors/New-B...QQcmdZViewItem
last time I discovered I had a starting problem was when my P didn't start...hope this helps.
1st time I blew (a fuse) had it towed and paid 175 bucks to get the fuse replaced (yes I am an idiot)
2nd, 3rd, 4th and 5time I drained the battery, left XM radio charger in lighter and last time I replaced the battery.....
Now my P drives like never before......Okay now I am reading your last post and you were referring to a actual starter!!! Anyway just read this for no reason.....
