996 Forum 1999-2005
I just installed the OEM Carrera wing, and I have a small problem...
Old 01-11-2008 | 11:01 AM
skiracer's Avatar
skiracer
Default I just installed the OEM Carrera wing, and I have a small problem...
When I exceed 75 mph and the mechanical wing doesn't raise (because it has been replaced by the fixed wing) I get an error message that I can clear, but the 'idiot light' stays on until I turn off the car and reset the system.
Did my installer forget to disable a circuit? I didn't see any reference to this item in the TSB I received from the seller of the wing on the installation procedure.
Yes, of course photos will be coming, but I've been traveling overseas for the past 3 weeks and the car is a mess.
Thanks in advance for any help.
Old 01-11-2008 | 11:04 AM
Doug Donsbach's Avatar
Doug Donsbach
Search is your friend:
https://rennlist.com/forums/showthre...+warning+light
Old 01-11-2008 | 11:19 AM
Marc Gelefsky's Avatar
Marc Gelefsky
Super Moderator
What, No pictures of the Wing installed??
Old 01-11-2008 | 12:01 PM
chsu74's Avatar
chsu74
I brought popcorn.
Old 01-11-2008 | 01:15 PM
LVDell's Avatar
LVDell
I got the drinks......
Old 01-11-2008 | 04:43 PM
Lazerblade's Avatar
Lazerblade
Old 01-11-2008 | 07:22 PM
MTB's Avatar
MTB
Did you use cable harness for fix wing?
996-612-070-51
Old 01-11-2008 | 08:46 PM
skiracer's Avatar
skiracer
I'm not sure, but my mechanic followed the TSB for installation. Doug- thanks for the direction but I couldn't get the search to locate the procedure. Any ideas?
Old 01-11-2008 | 08:52 PM
wross996tt's Avatar
wross996tt
Here you go:
Fixed wing
Old 01-11-2008 | 09:43 PM
skiracer's Avatar
skiracer
Thanks! That looks like it will help. I keep looking for your car when driving around Boulder Valley, but haven't seen it yet...
Old 01-11-2008 | 09:57 PM
TT Surgeon's Avatar
TT Surgeon
Check renntech, I had a post a couple of yrs ago about this, bottom line you must change out the harness, there are three different ones, one 40$, another 120$ and the last is the c4s aerokit harness 350$. I believe you want ~51 that was posted above.
Old 01-11-2008 | 11:38 PM
wross996tt's Avatar
wross996tt
Cause it goes to fast to see...
Quick Reply: I just installed the OEM Carrera wing, and I have a small problem...
