What could this "blip" be?
8th Gear
Hi all,
I have noticed recently a "blip" or hiccup--a sort of really quick misfire, although I hesitate to call it a misfire--as I cruise along the freeway in 6th gear at around 3k RPM. It happens randomly and there seems to be no drivability problems with the car, a 2003 911 with about 12k miles on it. I bought the car 3 weeks ago with about 10,800 miles on it, and it is my first Porsche. I'm wondering if this is just a characteristic of the way these engine management systems work or if it indicates something a bit more sinister. Any thoughts or ideas?
Thanks!
Deano
Thanks!
Deano
8th Gear
Thanks guys. Your suggestion that it could be the variocam gave me something to search on and, from several other posts, it seems this is common and normal.
Deano
Deano
Ironman 140.6
Variocam - Variable valve timing ('99-'01 996's)
Variocam plus - Variable valve timing and lift ('02-'04 996's)
http://wheeltalk.fancal.net/?p=366
Yeah - at about 3200 rpm, the hydraulics kick in and the valves lift higher. Definite bump at that point. Entirely normal, but I still try to avoid cruising at that speed to avoid constantly engaging the mechanism.
One guy on the board here runs 15-50 weight oil an dhe says it dampens the effect. Not recomended though.
