Noisy dashboard?
Hey guys.
I have a noisy dashboard and I wonder if anyone have experience this, it sounds like small cracking noise all the time, as soon the car moves.
I saw a thread on the 993 turbo forum that they had similare problem to mine and used some foam stuff, would it be the same fix for my 996?
Regards // Norbert
Regards // Norbert
Hey guys.
Regards // Norbert
Regards // Norbert
As it turns out in most cases -> the noise that appears to be from the dash is actually sound from the windshield moving and creaking. This was a common complaint with the 993. It reappears in some older 996's (mine included). The "6420" is a technical bulletin (Technical Service Bulletin-> TSB) put out by Porsche addressing this problem. TSB 6420 called "Noises in the Wind Shield and Rear Window Area". You can get it TSB's from Renntech. If you haven't joined there, you should, it's a great resource. http://www.renntech.org/forums/index...tsbs&code=menu
If you read the TSB, to fix this you need part number 996 541 903 00. One per windshield. It costs $15.00 from pelican parts, or any other parts place (even the dealer). It takes 15 minutes to do it yourself - all all you need is a spatula and a bucket of soapy water.
Now the reason that I said it was a good thread - was because you would never find the right search phrase "6420" without some SERIOUS hunting. Now ask me how I know
-td <-- replaced the gasket and there were no more creaks -> dash, windshield, headliner, or other
I found that the lower left corner of the passenger side airbag cover was my culprit. The corner is slightly loose and all I do is just push on it, and it's usually good for the rest of the drive.
Newbies Hospitality Director
TSB 6420 called "Noises in the Wind Shield and Rear Window Area". You can get it TSB's from Renntech.....
If you read the TSB, to fix this you need part number 996 541 903 00. One per windshield. It costs $15.00 from pelican parts, or any other parts place (even the dealer). It takes 15 minutes to do it yourself - all all you need is a spatula and a bucket of soapy water......
Chandler!
I usually spend more than $15 when it involves a spatula and soapy water, so this is a bargin.
Well pelican did ship to Sweden, just ordered that part!
But still cannot login into renntech, tryed recovering my psw , no email, reg a new account, still no email... strange site!
