Orange Cap mod
I am the only one on the board who has not done this.
Can someone just give me the dimensions?
I have caps like that at work in just about any size. I will try to hook up some newbies if I have the size.
I measured and it's about 1-3/4"
Newbies Hospitality Director
BTW - I'm just kidding! It will work in your car!
Originally Posted by gota911
Cory - don't worry about the Orange Cap mod... 'cuz it will not work on Tip cars. Sorry, dude, you are at a dis-advantage again!
If the opening is the same as the 997's - the cap to a Mobil One 5qt oil jug fits as well. It's not red and doesn't say Fabspeed or cost $200 but it still works.
For those that want more info - look for Helmholtz Resonator in your search.
I did the helmholtz delete about a year ago. I went with the Oatey test plug and a 996 silicone tube off ebay. I ended up taking it off because it felt like it lost low end torque. I revisited this mod about 2 weeks ago after I cleaned the throttle body and changed the air filter. I noticed that in 4th gear when I'm going past 5,500 rpm it takes longer to rev up than without it. I have since put it back to stock and it climbs faster now. Anyone else experience this?
