Old brake fluid symptoms?
I was wondering if old brake fluid would cause the brake pedal to feel less responsive and harder to press? The selling dealer claimed to have changed the fluids, but if not, maybe that is the cause of my strange feeling brakes?
I think that's pretty unlikely. If anything, given the mileage and age of your car, you'd probably notice a soft pedal if the brakes needed bleeding. FWIW, I find the pedal effort to be noticeably higher on these cars than on the 944s (since you owned those before, they may have calibrated your frame of reference), but the braking performance is really much better.
Oh. I find I feel like I have to stand on the brakes to get the same results I got from the 944 with only moderate pressure. In the 944, when I slammed on the brakes, the car stopped, very quickly. The 996 doesn't give me the feeling that the brakes are massive and super powerful.
Know what I mean?
Know what I mean?
I don't think you should equate instant grip to actual braking performance.
I know in my E46 M3 just a slight push on the brakes resulted in major stoppage, and in the 911 with the big brakes, I have to stand on it much more which I actually prefer and I know the 911 has better braking power than the M3.
I noticed that after my recent brake flush, the pedal feels firmer now, but braking perf is the same.
Originally Posted by AndyK
Know what I mean?
Originally Posted by 99firehawk
I see a water in the booser thread coming up
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
But seriously, what does water in the booster do?
Originally Posted by Doug Donsbach
Clogged drain allows accumulation of water, flooding booster, invading, corroding, and generally hosing your brakes.
My '05 Accord's brakes are right out of a 1975 Impalla - feel like "super power brakes", one touch, and you go flying into the seat belts!
They should not be grabby like a camry/accord/taurus or similar car, they should be gradual so you can modulate you braking. You can't do that as well with your accord.
Step on them and the car will stop! This is just the way the brakes are designed.
At lower speed it feels like the accord stops better, at higher speed it's another story.
i had some stronger brake due to the old brake fluid. it was like the front of the car wanted to stop, and the rear end keep pushing it. in tech term, brake force is not distributed correctly. it was fixed by fluid change.
btw, BMW brake feels like a on/off switch. never like it.
