996 Forum 1999-2005
why is the '99 superior to all years?
Old 07-17-2007, 05:18 PM
dallasboats
dallasboats's Avatar
Default why is the '99 superior to all years?
I'm told the '99 is the lightest and fastest of the bunch and Mk II's are ladden with motor failures and RMS issues. Obviously the weight advantage is huge................ Were the motors built by shorter factory workers than in the later years, I'm told this could account for the difference. I'm sorry for all of the MK II owners but at least it's water cooled and an improvement over the ill fated 993.
Old 07-17-2007, 05:26 PM
Greg D.
Greg D.'s Avatar
Haven't heard that - I bet you heard it from a 99 owner ;-)
The later models are supposed to have less engine and RMS failures... And the 3.6 are faster AFAIK.
Old 07-17-2007, 05:27 PM
TheSpeedDemon
TheSpeedDemon's Avatar
Never heard this before either, but if it is true
Old 07-17-2007, 05:35 PM
iJeremy
iJeremy's Avatar
We see the RMS failure across the board- everyone has their opinion as to what year it seems to happen most with, but from an un-biased opinion I'd say it has more to do with luck than model year unfortunatly.
Old 07-17-2007, 05:46 PM
Paul 996
Paul 996's Avatar
Has an RMS leak caused an engine failure??? Or is it just in fact a leaky seal that needs to be replaced when it starts leaking too much?
Old 07-17-2007, 05:47 PM
HD911
HD911's Avatar
Originally Posted by dallasboats
I'm told the '99 is the lightest and fastest of the bunch and Mk II's are ladden with motor failures and RMS issues. Obviously the weight advantage is huge................ .
99's are lighter but its not a huge difference, they were also the only year that Porsche offered a LSD in the n/a 996.
Old 07-17-2007, 05:48 PM
Paul 996
Paul 996's Avatar
What is that about? ill fated, please explain?
The 99 has the lowest HP 296 vs 300 and 320 for later models but is as you state the lightest of the bunch. It is also the only model where a LSD was available other than the 40th anniversary edition.
ill fated 993.
Old 07-17-2007, 05:49 PM
lanny
lanny's Avatar
Someone trying to stir things up maybe
Old 07-17-2007, 05:52 PM
Rob in WA
Cap'n Insane the Engorged
Rob in WA's Avatar
The only advantage is the mechanical throttle vs. e-gas and if the car has the LSD option.
Disadvantages - porous block issues and if the car doesn't have full leather you get the basketball dash material.
Old 07-17-2007, 05:56 PM
Riad
Chandler!
Riad's Avatar
I will go out on a limb and say it would be very difficult for anyone to convince me ANY first generation model year is the best.
Old 07-17-2007, 06:05 PM
Paul 996
Paul 996's Avatar
riad,
agreed in principle, but the 99 that we got was shaken down in 98 in europe
Old 07-17-2007, 06:08 PM
evansaero
evansaero's Avatar
Who told you this???
I think your Multiple Personality disorder is getting worse
The presence of two or more distinct identities or personality states (each with its own relatively enduring pattern of perceiving, relating to, and thinking about the environment and self).
At least two of these identities or personality states recurrently take control of the person's behavior.
Inability to recall important personal information that is too extensive to be explained by ordinary forgetfulness.
We can get you the help you need
Old 07-17-2007, 06:10 PM
ScottArizona
ScottArizona's Avatar
I've got a 99, early 98 build, with the basketball interior, and no lsd. I agree it is a vastly superior car than all later models. Anyone want to trade their 200_ for my 99
Old 07-17-2007, 06:12 PM
Paul 996
Paul 996's Avatar
As a 99 owner, I think it is a stretch to say it is the best year. Certainly there are aspects of that particular year if you have some of the options available that make it a little nicer of a car for track use. But as with anything the factory keeps making them a little better every year, usually.
Now as for this thing about the 99 engine being the most bullet proof.. Never heard that before but like someone said that wouldn't hurt
Old 07-17-2007, 06:26 PM
newport996
newport996's Avatar
99's are MORE prone to engine failure....RMS is probably about the same..the car is SLIGHTLY lighter, and LSD was an option in that car, as well as a mechanical throttle vs. e-gas.....
Quick Reply: why is the '99 superior to all years?
