Group Buy - Aluminum Pedals
#301
Andy,
Don't be such a puss! Install them, it really is NOT that hard.
The gas & dead pedal take about 3 minutes each to install:
o - align each on the OEM pedal
o - drill two small pilot holes
o - screw the aluminum pedal to the OEM pedal
o - DONE!
The clutch & brake pedals take about 15 minutes each to install. Two screws install in about 3 minutes each:
o - remove OEM rubber pedals
o - use double sided tape or spring clamps to position pedals. Make sure they are even. By design, the clutch pedal sits a little lower than the brake pedal, which is not really noticeable with the OEM rubber pads on them. However, this difference will be more noticeable when you install the aluminum pedals.
o - mark the three holes on each pedal.
o - use a titanium drill bit to drill the holes. Clutch will take about 10 - 15 seconds per hole, brake will take about 45 seconds per hole.
o - Insert small bolt and snug up the nut on the back of the pedal. This is the most "pain in the ****" part, but once you get the nut started, use a screwdriver to turn the bolt and tighten the nut.
o - repeat the step above 5 times
o - DONE!
Andy, I took the time to write this because I hoped I could convince you that it really is NOT that hard. I don't have much time left with my P-car (she goes back to the Lease Company at the end of May) and I am really going to miss the car. I am hoping I can convince you that the result is worth the effort.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
o - DONE!
o - DONE!
Yup, I think it's one of those "must-do" mods that is low effort compared to the huge cosmetic improvement that it provides.
#303
Newbies Hospitality Director
You are welcome. I guess I was too late to convince Andy to install them.
After you get them installed, make sure you tell Andy how relatively easy it was.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#304
Too late is right! I just spent a small fortune buying painted bumperettes from Bumperplugs, so the proceeds from the pedal sale will be put to good mod use!! Bye-bye black eye sores!
#308
#311
Did you just really dig up a 3 year thread for an expired group buy? I see a banning in your immediate future
![nono](https://rennlist.com/forums/graemlins/nono.gif)
#312
Thanks for resurrecting this thread. I found a nice set for my Tip on ebay. They were listed for a 997, but I contacted the seller and they had same for 996. Apparently, slight difference in the dead plate size between 997/996.
The installation details in this thread are very helpful, and I salute the contributors!![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
