All Season Tire recommendation
#32
My car came with P-Zero Rossos and although they all had at least 50% tread remaining, after 5K miles the fronts still had plenty of tread left, but the rears were bald. Being advised not to mix tire types, I was about to buy 2 new Rossos for the rear, but then a friend of mine told me he uses Bridgestone RE960AS on his 997. It's pretty much always "summer" here in FL and I hesitated about putting an All-Season tire on mine, but when he told me after almost 25K miles his are hardly worn at all, and that I can put a set of 4 on for about what it would cost for 2 rear Rossos (that will last what, 10K?), I went for it. As a bonus, they ride softer and quieter than the P-Zeros, which makes my enjoyment of the car even better.
#33
I STRONGLY disagree here. I have to say everyone busted my stones about Good Year F1 AS.... Well the other night I got stuck in some of the worst trenching down poors or rain I have ever been in.... That car never drifted ONCE, it was stuck to the road as if it was dry. Fabulous tire.
#34
I just bought a set of 18" Turbo Twists for my 99 Cab. They came with a set of Michelin Pilot Sport AS Plus already mounted. My 17's had Conti Sport Contacts which I thought were great tires. I just installed the "new" wheels and tires today and went for a short drive. Once I've had a chance to drive them some more I'll add my impressions.
#35
I just bought a set of 18" Turbo Twists for my 99 Cab. They came with a set of Michelin Pilot Sport AS Plus already mounted. My 17's had Conti Sport Contacts which I thought were great tires. I just installed the "new" wheels and tires today and went for a short drive. Once I've had a chance to drive them some more I'll add my impressions.![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
#36
After trying all-seasons on my C-4 (older car/tires, however) I am also in the 2 set camp.
If you check around, some tire changers, shops, etc, will store your extra tire/wheel sets - might be worth looking into. Maybe the storage fee might make the swapping twice yearly more do-able (is that a word??)
#37
Team Owner
Summers in winter are fine on dry roads. I've driven even through snow storms but stayed on the ploughed hwy's with them and that was scary you wouldn't ever want to do that. Also I really mean dry roads. I've hit a snow drift on dry roads and totally lost it and ended up with big time curb rash.
Your car will not explode if you drive on summer tires in the winter, but when you need grip the most, it will not be present.
It's just not a good idea.
#38
The A/S discussion will always prevail, and in some climates, it can make sense. But I agree with the general wisdom on here regarding 2 sets. I did not, however, buy a 2nd set of wheels, because my wheels are only $150 each to replace. I think Porsche wheels are actually pretty strong and can stand up as well as aftermarket ones to the elements.
#39
All right. Let's drag this one out again. Have had a chance to do a bit of spirited driving on the Pilot Sport A/S Plus tires. The main impression I get is that they are good for all around driving (I use it as a good weather DD) but when you start to push them the fronts start to squirm a bit and the car starts to move around. The front was alway pretty lively before but with these you need to be more on top of it. The rears seem to be pretty dialed-in and I never had the impression that they would break loose. Under heavy braking the Pilot's will squeal which is something I never experienced with the Conti's. Indicative of a harder tire I also don't get the burning rubber smell I used to get on previous Pirelli's and Conti's every time I open the driver's door after a hard drive (that one freaked me out when I first got the car!!). Overall just not as tight a feeling as the Conti's I had on before - not really bad, just not as good.
On the plus side I'm really pleased with the look of the car with the 18" Turbo Twists - dramatic improvement over the stock 17's, even though my wife says it looks the same!!!![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
#40
Not sure if the sizes are available for Pcars, but I had a set of 235/40R-18 Bridgestone Turanza Serenity XLs installed on my Audi last December. Quiet, grippy in hot, cold, dry, wet, and and I confirmed they also work well in snow.
http://www.tirerack.com/tires/tires....ranza+Serenity
#41
Ironman 140.6
Ugh, all season tires on a 911. Did I accidentally enter the Prius forum?
It's unfortunate that threads this silly can't seem to stay dead. Furthermore, I think you're crazy if you plan on driving a 911 in Calgary all winter on all season tires.
I have several Chicago winters under my belt with the 911 and IMHO snow tires are essential for driving a 911 in conditions with any snow.
#42
Rocky Mountain High
You never know what will happen, on the road or on the track.
Last Friday, I was driving home on I-70 at about 8:00 PM and a knucklehead ahead of me managed to spin his car on the interstate at ~70 mph. I was VERY happy to have good summer rubber on my car that allowed me to swerve around him and narrowly avoid hitting him. Could I have done this with all-season tires? Probably... but why take the chance?
#43
Newbies Hospitality Director
#45
Team Owner
Ray is 100% correct. Installing all-seasons on a car like this is neutering it. You've paid for a certain level of performance and safety and all-season tires arbitrarily limit both. It's like paying for a 3/4-ton pickup but never once hooking a trailer to it.
